Fixing up a 2000 with 'Undercarriage' damage (Pictures Enclosed) - Ford Truck Enthusiasts Forums
Old 05-10-2011, 02:33 PM
EddyD EddyD is offline
EddyD is starting off with a positive reputation.
I posted a somewhat irrelated thread a few days ago regarding buying a different truck. I included some details about this truck, however I thought I'd make a general thread with pictures, etc.
Here is a 2000 F150 that I am currently have. I may just fix this and keep it provided it's a decent idea. It has 114,000, 4 wheel drive. It has an odd problem where the oil pressure guage doesn't go up (it use to), sometimes it will shoot up to normal for a while - but eventually it goes back down. I have that black out dash issue listen in the FAQ though. Prehaps the two are related.
My main concern though are the frames/undercarriage... shocks, springs, etc. I'd be curious what everyones general opinions are of what would need to be repaired to make the truck a strong daily driver. (As of now it's not.)
The pictures start at the front drivers side, go to the back, around to the rear passenger to the front and then show under the motor.
I appreciate the help.
Ed
Old 05-10-2011, 03:03 PM
brokenleg brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
I can see you got problems up front.....where the frame is rusted through where that bracket is........... alot of what I see is alot of surface rust, and alot of bolts are rusty. I would check all the brake lines...............
as for the oil pressure, I notice that the oil filter has been on there long enough to get rust..........that would make me wonder about the engine.....
1988 F-350, 460 EFI Having All Kinds of Issues OkieFromMuskogee 1987 - 1996 F150 & Larger F-Series Trucks 10 01-25-2015 08:23 PM
Fully Stock 1994 Ford F150 Restoration ~with Pictures~ Gater180 1987 - 1996 F150 & Larger F-Series Trucks 26 09-09-2014 05:07 PM
1951 F4, Is this worth anything? Viewers beware Dr. Pepper PhD. 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 08-11-2014 03:55 PM
1978 rebuilt shotgun2 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-07-2012 12:04 PM
finally got her lifted!!! pic heavy... jlmotox 1999 to 2016 Super Duty 30 04-01-2009 03:10 PM
Tags
2002, 2003, 2010, carriage, damage, damaged, escape, expedition, f150, fixing, ford, illustrations, images, picture, rear, truck, undercarriage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
