How to tell is HPOP is going bad?
Old 05-10-2011, 01:00 PM
smash fascism's Avatar
smash fascism
smash fascism is offline
I have a 97 F350 with 185,000 miles on it, stock injectors, and all the mods in my sig. It seems like when I start my truck up cold and drive it, it seems like its lacking in power until it warms up. Is this normal? It also seeems to smoke more when its cold and i lean into the throttle than when it has warmed up. Was thinking i might have weak/leaking injectors or a bad HPOP. I also get a strong fuel smell from my tail pipe that seems stronger than it should be.
Thanks in advance.
Old 05-10-2011, 02:12 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Nothing your describing seems abnormal. The fuel odor might be a concern if it was constant. If its there only when the engine is cold that seems pretty normal to me too.
Old 05-10-2011, 03:03 PM
JamesHajek's Avatar
JamesHajek
JamesHajek is offline
Our engines are dogs when cold. Gotta give it some time to warm up.
Smoke is not abnormal as well as long as it goes away.
To test the HPOP you would have to have a scanner to ICP and duty cycle.
Old 05-10-2011, 10:56 PM
clean '97's Avatar
clean '97
clean '97 is offline
maybe egpv engaging when it's cold? wag!!
Old 05-10-2011, 11:06 PM
smash fascism
I didnt think about that, my egbv is wired open, could that be why it reaks like fuel?
Old 05-10-2011, 11:09 PM
JamesHajek's Avatar
JamesHajek
Wired open would not be the issue... If it was closing, that would cause a lack in power...
Action4478's Avatar
Action4478
Action4478 is offline
No ..
Are you due for an oil change?
Get it on a scanner , let us see some live data...
My WAG is the IPR is sticking ...
Old 05-10-2011, 11:11 PM
smash fascism
yeah I know that, when the actuator broke it was a dog until i wired the butterfly open. im going to take that housing off this weekend and do the delete to it.
Old 05-10-2011, 11:25 PM
Action4478's Avatar
Action4478
What part did you know ?
Old 05-11-2011, 09:12 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Talking
I think he answer to James, you wrote at the same time your WAG and I think he hasnt answered to you.
Old 05-11-2011, 12:59 PM
smash fascism
What is the ICP?
Old 05-11-2011, 02:02 PM
JamesHajek's Avatar
JamesHajek
ICP = Injection control pressure...
20powerstroke02
02-18-2017 07:17 AM
Rich21
21
02-14-2017 09:25 PM
OldBlack4x4
08-03-2016 11:01 PM
tshrager
68
02-19-2013 08:48 PM
Quick Reply: How to tell is HPOP is going bad?
