How to tell is HPOP is going bad? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-10-2011, 02:00 PM
smash fascism's Avatar
smash fascism smash fascism is offline
smash fascism is starting off with a positive reputation.
I have a 97 F350 with 185,000 miles on it, stock injectors, and all the mods in my sig. It seems like when I start my truck up cold and drive it, it seems like its lacking in power until it warms up. Is this normal? It also seeems to smoke more when its cold and i lean into the throttle than when it has warmed up. Was thinking i might have weak/leaking injectors or a bad HPOP. I also get a strong fuel smell from my tail pipe that seems stronger than it should be.
Thanks in advance.
Old 05-10-2011, 03:12 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Nothing your describing seems abnormal. The fuel odor might be a concern if it was constant. If its there only when the engine is cold that seems pretty normal to me too.
Old 05-10-2011, 04:03 PM
JamesHajek's Avatar
JamesHajek JamesHajek is offline
JamesHajek is gaining momentum as a positive member of FTE.JamesHajek is gaining momentum as a positive member of FTE.
Our engines are dogs when cold. Gotta give it some time to warm up.
Smoke is not abnormal as well as long as it goes away.
To test the HPOP you would have to have a scanner to ICP and duty cycle.
Old 05-10-2011, 11:56 PM
clean '97's Avatar
clean '97 clean '97 is offline
clean '97 is starting off with a positive reputation.
maybe egpv engaging when it's cold? wag!!
Old 05-11-2011, 12:06 AM
I didnt think about that, my egbv is wired open, could that be why it reaks like fuel?
Old 05-11-2011, 12:09 AM
JamesHajek's Avatar
Quote:
Wired open would not be the issue... If it was closing, that would cause a lack in power...
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
No ..
Are you due for an oil change?
Get it on a scanner , let us see some live data...
My WAG is the IPR is sticking ...
Old 05-11-2011, 12:11 AM
yeah I know that, when the actuator broke it was a dog until i wired the butterfly open. im going to take that housing off this weekend and do the delete to it.
Old 05-11-2011, 12:25 AM
What part did you know ?
Old 05-11-2011, 10:12 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Talking
Quote:
I think he answer to James, you wrote at the same time your WAG and I think he hasnt answered to you.
Old 05-11-2011, 01:59 PM
What is the ICP?
Old 05-11-2011, 03:02 PM
JamesHajek's Avatar
ICP = Injection control pressure...
white/blue smoke when started cold and surging 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 5 01-17-2017 07:46 AM
Year old injectors bad? OldBlack4x4 1994.5 - 1997 7.3L Power Stroke Diesel 9 08-04-2016 12:01 AM
02 7.3 how fast will bad injector/oring bleed down a reservoir alchemy455 1999 to 2016 Super Duty 0 02-27-2013 01:51 PM
'02 7.3 runs better with cold engine? 79str8six 1999 - 2003 7.3L Power Stroke Diesel 5 02-25-2013 11:13 PM
Bucking when cold tshrager 1994.5 - 1997 7.3L Power Stroke Diesel 68 02-19-2013 09:48 PM
Tags
2004, 60, 73l, 94, 97, bad, computer, f150, f250, f350, ford, fuel, hpop, lightning, mpg, pump, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
