2011 Shudder at 5 kph
  #256
Old 03-19-2012, 11:53 PM
Eric Landstrom's Avatar
Eric Landstrom
Eric Landstrom is offline
For the shudder on take off, install a set of Roadmasters to sort it out.
http://www.axlewrap.activesuspension.com/
It'll sort out the axel wrap we feel as a shudder on take off.
  #257
Old 03-24-2012, 10:38 AM
ericnottelin's Avatar
ericnottelin
ericnottelin is offline
Ok, let me ask this question. Has anyone had this problem with a 2012? I am considering getting a 12 screw eco 4x4 w/ max tow. I have read every post. I didn't see one 2012 with this problem. Did Ford resolve this with the 2012 model year?
  #258
Old 03-24-2012, 10:19 PM
sranderle's Avatar
sranderle
sranderle is offline
I'm also interested in 2012 feedback, as I'm about to order a new Screw 4x4 Eco HD.
  #259
Old 03-25-2012, 04:27 AM
gillis9's Avatar
gillis9
gillis9 is offline
2012
2011 with vibration
2012 without vibration.
Before signing the contract I have required the seller to make a road test (vibration test) I did.
I asked to have the truck as long as necessary.
With all the testimony, evidence of vibration on the two main forums you can require .
2012 FX4 5.0 145" 5.5
Gilles
Quebec
Canada
  #260
Old 03-25-2012, 08:04 AM
ericnottelin
Just fyi, I test drove a 12 eco screw 4x4 short bed. purposely drove slow to see if it would shutter as you guys have mentioned. didn't feel a thing.
  #261
Old 03-25-2012, 08:21 AM
MrCruisin55's Avatar
MrCruisin55
MrCruisin55 is offline
It is extremely rare to find a short box that shudders at takeoff, however I have heard of 2012 Screw's with the same shudder problem, in fact the problem has existed for at least 3 model years from what I understand
  #262
Old 03-25-2012, 08:28 AM
MrCruisin55
As I had mentioned in an earlier post my neighbor has an 11 FX4 Screw and he claims that his does not shudder.........go figure. Everyone's driving habits are different and some folks may be more sensitive to others when it comes to picking up ride sensitivities etc. This may be due to what they were driving previous to the Screw. Let's face it if you were driving a noisy bumpy piece of crap before owning a Screw you would think that driving the Screw was comparable to driving a Lincoln!
  #263
Old 03-25-2012, 09:46 AM
flixden's Avatar
flixden
flixden is offline
I am sure that's true, it's all relative.
I had a vibration coming from the front diff in my Tacoma after leveling. I met a guy on a forum who INSISTED he did not have that problem. He lived in the same area as me, and we met in person. Sure enough, vibe was there on his truck also, even more than on mine. He noticed it also after I showed him. He was not really happy about that, LOL.
  #264
Old 03-25-2012, 10:03 AM
MrCruisin55
I should have mentioned in my earlier posts that I am referring to the 6.5' box owning the shudder problem. I have a Red Candy 2011 F-150 4X4 157" wheelbase 5.0 with XTR Package
  #265
Old 03-25-2012, 11:25 AM
ilmo's Avatar
ilmo
ilmo is offline
There have been some that claim that the after market Roadmaster Active Springs solves the shudder issue by eliminating axle wrap and wheel hop. I have not installed them, but have considered the idea, although they are $350-$400 for a pair.
  #266
Old 03-25-2012, 11:43 AM
MrCruisin55
I was the first on this board to post that I installed a set of Roadmaster Active Suspension.
It did reduce the shudder quite substantially but did not eliminate it totally. The truck handles better in the corners as well especially under load as there is less spring deflection during weight shift if carrying cargo.
  #267
Old 03-25-2012, 11:28 PM
jimmyb08SD's Avatar
jimmyb08SD
jimmyb08SD is offline
I would think the roadmasters are only masking the problem, all of these trucks have the same springs, so if it is spring wrap they should all have it reguardless of cab or bed config. This has to be a drive shaft / wheel base issue. Just a thought!
Does anyone with a supercab and 8 ft bed have this issue? Should be the same wheel base as a screw with a 6.5 bed.
  #268
Old 03-26-2012, 08:59 AM
flixden's Avatar
flixden
flixden is offline
The HD payload springs seems to be another solution.
I get a little bit of the shudder with extreme loads only, but even then not as much I think as what people described here. I am talking about 2K lbs loads, and even then it does not shudder when I take it very easy on the throttle until 5 mph.
I have absolutely no shudder unloaded or with light loads. I had 12 40lbs bags of top soil in my bed yesterday and 3 people, with no shudder.
Considering that stiffer springs seem to help I would think that this is axle wrap. Of course, the ride won't be as smooth with those springs.
  #269
Old 03-26-2012, 10:50 AM
SRT's Avatar
SRT
SRT is offline
Is anyone with a one piece drive-shaft experiencing this problem; or is it confined to just the models with two piece drive-shafts?
  #270
Old 05-03-2012, 07:54 PM
Jon R's Avatar
Jon R
Jon R is offline
xxxxxxxxxxx
Quick Reply: 2011 Shudder at 5 kph
