2011 Shudder at 5 kph
#61
Credit should be given to jimmyb08SD as it is his idea. And he is trying compile information to see if there is a pattern for this problem on like trucks, or is it happening to trucks that are different (eg. 6.5' vs 5.5' beds, SuperCrew vs SuperCab, one piece drive shaft vs two piece drive shaft).The information that we can all provide may help us come up with a solution.The mounted camera is a great idea that may help Ford diagnose the problem and then come up the resolution.
#62
1. 2011 Screw 6.5 bed, 4x4, 3.5 EB, 3.73 rear, Ca., present all takeoffs in low gear, empty or loaded
2. 2011 Super Crew 6.5' bed, 4x4, 3.5L EcoBoost, 3.55LS, 5800 miles, shudder present @ 3-5 mph in 1st gear only, empty. Never seen salt. Built March 23, 2011.,
3. 2011 Super Crew 6.5" bed, 4x4, 5.0 V8, 3.73 LS, 5500 miles, shudder present @ 3-5 mph. Built November 2010.
#63
4. 2011 SCREW 6.5' Bed, 4x4, 5.0L, 3.73LS, 3000 Miles, shudder present @ 3-5 MPH. Built Dec. 2010 Hasn't seen salt(yet). Shudder more evident under load.
As a side note, I bought Firestone Ride-Rite Air bags and compressor... once the bags are installed I will run them up with air to stiffen the rear susp. and see if the shudder is still present. I am of the belief the shudder is from the 2 pc drive shaft, but this is a way to eliminate or confirm the axle wrap theory as the bags will hold the leafs in place.
#65
Found this on another forum.
Ford just came out with this today!
2011 F-150 WITH THE 3.5L OR 5.0L ENGINE AND 6R80 TRANSMISSION BUILT ON OR BETWEEN 2/1/2011 TO 4/1/2011 SHUDDER DURING 2-1 DOWNSHIFT 5-7MPH (8-11KPH)
SOME APPLICATIONS OF THE 2011 F-150 VEHICLES WITH THE 3.5L OR 5.0L ENGINE BUILT ON OR BETWEEN 02/1/2011 UNTIL 4/1/2011 MAY EXHIBIT A SHUDDER DURING A 2-1 COASTING DOWNSHIFT TYPICALLY FOUND AT SPEEDS OF 5-7 MPH (8-11KPH). USE IDS TO MONITOR FOLLOWING PIDS, IN_GEAR MODE,GEAR_RAT, VSS TO VERIFY IT IS THE 2-1 DOWNSHIFT. IF THE SHUDDER IS ONLY PRESENT ON THE 2-1 COASTING DOWNSHIFT REPLACE THE C-CLUTCH (INTERMEDIATE) FRICTION PLATES FOLLOWING WSM SECTION 307-01 AND USE AVAILABLE SERVICE LABOR TIME STANDARD OPERATIONS. IF THE SHUDDER OCCURS AT ANY OTHER VEHICLE SPEED OR GEAR CHANGE EVENT DISREGUARD THIS PROCEDURE AND FOLLOW NORMAL WSM SECTION 307-01 DIAGNOSIS BY SYMPTOM FOR FURTHER DIAGNOSTICS
#66
Here is another.
Heres Another TSB on Ecoboost engines also just came out today.
2011 F-150 3.5L ECOBOOST - INTERMITTENT MISCELLANEOUS DTCS FOR UEGO SENSOR / TRANSMISSION
SOME 2011 F-150 VEHICLES EQUIPPED WITH A 3.5L ECOBOOST ENGINE MAY EXHIBIT AN INTERMITTENT MIL LIGHT WITH MISCELLANEOUS HEATED OXYGEN SENSOR BANK 1 OR TRANSMISSION DTCS, A LACK OF POWER COMPLAINT, OR SHIFT QUALITY ISSUES. INSPECT THE ENGINE HARNESS TAKEOUT FOR THE BANK 1 UEGO FOR A CHAFE CAUSED BY THE TRANSMISSION CASTING. IF WIRING CHAFE IS NOTED ON THE ENGINE HARNESS, REPAIR THE HARNESS AS PER ONLINE WIRING DIAGRAM (EVTM) SECTION 5 PAGES 5-8 AND WRAP THE HARNESS WITH CONVOLUTE. IF NO WIRING CHAFE IS PRESENT, PROCEED WITH NORMAL PC/ED OR WSM DIAGNOSTICS FOR THE CODES OR SYMPTOMS PRESENT.
#68
Shudder when starting and stopping on 09 F150
I have the same problem as well and this is what I could find so far on various websites, I have only 17000 kms so far and only notice it at those times. This is what i found at the present time.
<TABLE border=0><TBODY><TR><TD width=230></TD><TD>2009-2010 F-150 </TD></TR></TBODY></TABLE>
ISSUE:
TSB
09-25-5
Some 2009-2010 F-150 vehicles equipped with a 2 piece driveshaft only and built on or before 12/1/2009 may exhibit a rear driveshaft slip/bump concern on light to moderate acceleration from a stop or when coming to stop with light braking.
<TABLE border=0><TBODY><TR><TD width=230>FORD:
</TD><TD>2009 F-150</TD></TR></TBODY></TABLE>
ISSUE: 5.4L 3V 6R80 HARSH 1-2 UPSHIFT, BUMP WHILE COASTING LOW SPEED DOWNSHIFT, HARSH DOWNSHIFT TO 4TH GEAR - INTERMITTENT P0741
TSB
09-11-5
Some 2009 F-150 vehicles equipped with 5.4L 3V engine and equipped with a 6R80 automatic transmission may exhibit the following symptoms during warm-up: a harsh 1-2 upshift, harsh 2-1 downshift while coasting 15 MPH (24 Km/h). A harsh downshift into 4th gear at highway speeds 45-70 MPH (72-113 Km/h) may also be experienced. Some vehicles may have a diagnostic trouble code (DTC) P0741 torque converter performance code present or stored.
ACTION:
Follow the Service Procedure to correct this condition
SERVICE PROCEDURE
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>DO NOT ATTEMPT TO REPLACE THE MECHATRONIC UNIT. MECHATRONIC REPAIR/REPLACEMENT IS NOT AUTHORIZED FOR THIS ISSUE.</TD></TR></TBODY></TABLE>
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH align=middle>OPERATION</TH><TH align=middle>DESCRIPTION</TH><TH align=middle>TIME</TH></TR><TR><TD class=NOBOTTOMBORDER align=left>091105A</TD><TD class=NOBOTTOMBORDER align=left>2009 F-150 6R80 Transmission: Check DTCs, Reprogram The PCM And TCM, Includes Time To Clear The TCM KAM And Perform Road Tests (Do Not Use With 12650D, 12651D, 12651D4)</TD></TR></TBODY></TABLE>
ISSUE:
TSB
09-25-5
TSB
09-11-5
ACTION:
SERVICE PROCEDURE
- Install IDS/PDS or equivalent and ID vehicle.
- Update the powertrain control module (PCM)/transmission control module (TCM) calibration using IDS release 60.14 and higher or 61.04 and higher. This new calibration is not included in the VCM 2009.5 DVD. Calibration files may also be obtained at Buy Motorcraft Parts Online | Official Motorcraft Auto Parts Site | FordParts.com.
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>THE TCM CANNOT BE INDEPENDENTLY REPROGRAMMED, REPROGRAM USING THE PMI FUNCTION TO ENSURE THAT ENGINE AND TRANSMISSION CALIBRATIONS ARE UPDATED TO THE LATEST LEVEL SIMULTANEOUSLY.</TD></TR></TBODY></TABLE>- Verify that the TCM Calibration shows AL3P-7J104-AB (4x2) or AL3P-7J104-BB (4x4) part number after reprogramming is complete by selecting the following from the IDS tool.
- Toolbox
- Powertrain
- OBD Test Modes
- Mode Level 9 - Vehicle Information
- TCM Cal Part Number
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>IT IS CRITICAL THAT TCM KAM BE CLEARED FOR THIS PROCEDURE TO BE FULLY AFFECTIVE.</TD></TR></TBODY></TABLE>
- Clear TCM keep alive memory (KAM) and adaptive tables
- Using IDS:
- Open Toolbox
- Choose Powertrain
- Choose Reset KAM
- Then Choose TCM
- Using PDS:
- Choose all Tests and Calibrations
- Scroll down the menu and choose reset TCM KAM
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>FOR PDS, RESET TCM KAM IS NOT THE SAME AS CLEAR TRANSMISSION ADAPTIVE TABLES, WHICH IS UNDER THE POWERTRAIN - TRANSMISSION MENU TREE. </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>UNHOOKING THE BATTERY WILL NOT CLEAR THE TCM KAM. IT IS CRITICAL THAT TCM KAM BE CLEARED PRIOR TO RELEARNING THE ADAPTIVE TABLES FOR THE TRANSMISSION. </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>DO NOT CLEAR THE PCM KAM.</TD></TR></TBODY></TABLE>
- Using IDS:
- Verify that the transmission fluid temperature (TFT) PID is above 175 °F (80 °C). If it is not at 175 °F (80 °C), drive unit approximately 3 miles (5 Km) to reach temperature.
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>TFT MUST BE AT 175 °F (80 °C) OR ABOVE BEFORE PROCEEDING TO STEP 5.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>PERFORM ADAPTIVE SHIFT STRATEGY LEARN ON LEVEL SURFACE ROAD.</TD></TR></TBODY></TABLE> - Drive unit to perform adaptive shift strategy learn.
- Accelerate from rest with light throttle to 15 MPH (24 Km/h), remove foot from accelerator pedal.
- Brake very gently to a complete stop (allow at least six (6) seconds).
- Repeat steps (a-b) five (5) times in the dealership parking lot or similar setting.
- Accelerate from rest with light throttle ensuring that the 1-2, 2-3 and 3-4 shifts occur at engine speeds between 1700-2000 RPM.
- Continue to accelerate until you achieve 50 MPH (80 Km/h) or the 5-6 upshift.
- Brake gently to a complete stop and hold foot on brake for ten seconds.
- Repeat steps (d-f) three (3) times.
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>SEVERAL DAYS OF DRIVING ARE REQUIRED FOR THE TRANSMISSION TO FULLY ADAPT.</TD></TR></TBODY></TABLE>
#69
#70
Well guys, I think I’m the first of us to have been towed to the dealer! What a father's day I had... Brand new 2011 F150 3.5L Ecoboost FX4 Crew with 6.5' box. Only 1,000 miles on it before my first tow. I have a roughly 7,000lb camper. Truck towed awesome to the campsite. I did notice the shudder when taking off, but only towing. On the way home I noticed a cloud of white smoke billowing out of the rear. I pulled over and noticed tranny fluid dumping on the ground. All over the under-side of my truck and on the camper. I limped to the next exit about a mile away and called the tow truck. I had gears still, so it can't be too bad. Didn't notice a crack in the case at all. Prior and during there were no temp spikes at all... trans temp was reading normal. Could have busted a line, or fitting... or maybe even the stupid drain plug wasn't tight from the factory, who knows.
My dealer just called me and will be looking into it. I did tell them about the shudder as well. I'll keep everyone updated.
(At least it was a Ford towing a Ford!)
#72
#75
Okay, sorry about my last post. I would like to help since if the probelm is trans related it will spread to all trucks.
Questions for those with the issue:
1. If the traction control is turned off, is the shudder present when towing or under load?
2. If the traction control and advance trac are turned off, is the shudder present?
3. Is the shudder present when the trans fluid is cool or only once it warms up?
4. Is the shudder present when the trans is shifted manually by placing the shifter in M and shifting it at higher rev points?
5. If the traction control, advance trac are turned off and the tow/haul button is depressed is the shudder still present?
These are important questions that we all would like answered to help. They all connect to the shift program that ford uses and identifies if the shift program has too low of pressures or if the converter is locking and unlocking between gears. I am asking this since the manual says the converter is not locked up until higher gears when the tow/haul button is pressed. If the shudder is shift related, then the pressures are too low or the converter may be engaging at too low of a speed and in too low of a gear. Lets trouble shoot where the dealer won't because the techs don't get paid to fix a part, just replace it.
