F150 Leaking Oil - Ford Truck Enthusiasts Forums
F150 Leaking Oil
Old 12-10-2002, 02:05 PM
Border3899 Border3899 is offline
Border3899 is starting off with a positive reputation.
F150 Leaking Oil
I have a Ford F150 which is leaking oil. It appears to leak more oil when the truck is moving rather than just sitting. The oil is also milky every now and again when i check it, not always just once in awhile. Wondering what would cause this?
Old 12-10-2002, 02:40 PM
tonys67 tonys67 is offline
tonys67 is starting off with a positive reputation.
F150 Leaking Oil
mine leaks out of the air cleaner box, into the drivers side fender. see the replies that I'm getting on the discussion listed above yours.
Old 12-10-2002, 07:34 PM
XjerseydevilX XjerseydevilX is offline
XjerseydevilX is starting off with a positive reputation.
F150 Leaking Oil
milky oil can be caused by antifreeze in th oil, i.e. a bad head gasket. your oil leak is best determined by getting underneath the truck and seeing where it is coming from. as most older trucks have a decent amount of sludge around the engine, try cleaning the motor with some of that engine cleaner. run the truck and see whereabouts you leak is coming from.
Old 12-13-2002, 10:15 AM
F150 Leaking Oil
Does anyone know if a bad PCV valve would cause moisture to get into the oil?
Old 12-13-2002, 01:26 PM
F150 Leaking Oil
moisture can be from short trips. engine oil doesn't get hot enough to burn off the condensation that forms, especially in winter/cooler climates. when you say that it isn't always present, it sounds like the short trips may be the cause.
Old 12-13-2002, 01:56 PM
F150 Leaking Oil
I drive approximately 40 miles to work, two days ago i left work drove 3 miles and checked the oil and it was milky, checked again yesterday morning and it was milky. I then checked it last night before leaving work and it looked fine. I'm more less trying to determine if the head gasket is bad or the rings are shot. I am running a compression check on it this weekend but am trying to see what i might be looking at for repairs.
Old 12-13-2002, 02:00 PM
F150 Leaking Oil
One other quick question does anyone know an approximate cost of a compression check and a coolant system pressure check?
Old 12-13-2002, 05:46 PM
edenroadmaster edenroadmaster is offline
edenroadmaster is starting off with a positive reputation.
F150 Leaking Oil
awayto check for a bad head gasket is to start it with the rad. cap off and wait for the thermostat to open. if the head gasket is blown, it should pressurize the cooling system and eithermake lots of bubbles or throw antifreeze out of the filler neck depending on how bad it is.
eden
Old 12-13-2002, 05:48 PM
F150 Leaking Oil
Thank you for your help, i will try this tomorrow morning to determine where the trouble is.
Old 12-16-2002, 11:29 AM
chuckman chuckman is offline
chuckman is starting off with a positive reputation.
F150 Leaking Oil
Old 12-16-2002, 12:21 PM
F150 Leaking Oil
I pulled the radiator cap off this weekend and did not have any problems with antifreeze bubbling or squirting through the filler neck. Could this mean i've got a cracked head or block?
side panel oil leak? heartlandcowboy90 1987 - 1996 F150 & Larger F-Series Trucks 4 11-20-2012 08:57 AM
97 4.2 F150 Coolant leaking into oil? lilflippy 3.8 & 4.2L V6 0 05-23-2012 05:17 PM
95 f150 oil leak seabasstard 1987 - 1996 F150 & Larger F-Series Trucks 8 02-04-2009 05:46 PM
new oil leak g tinsley 6.0L Power Stroke Diesel 2 10-31-2007 03:11 PM
The Best Oil for a 200,000 mile 300 herothc2003 Oil & Lubrication 6 11-30-2006 07:42 AM
Tags
1996, 2000, 2001, 2004, 49, 91ford, f150, ford, head, leak, leaking, leaks, motor, oil, oit, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
