Can you pull a 5th wheel with a 150 supercrew?
Ford does not reccommend it even in stock truck form.
With your lift and the frontal area of the trailer and other issues, your foolish to even attempt it.
The trailer weight like this is not the same as a hitch tow type.
The box weight load rateing is only about 1200 lbs +/-and is reduced further by other loads you have in the trailer and in the cab.
What you think you can tow goes out the window with this set up.
Another point never considered is in event of accident involving another vehichle, the insurance company may not back you with an unsupported set up like this.
I know that if I were to see you coming down the road with this setup the response would be 'wow look at that'! Police might think the same as well.
Good luck.
Good luck.
Car/truck Buying Advice
12-14-2016 11:13 PM
4bigred
Fifth Wheel & Gooseneck RV Towing
01-23-2009 06:30 PM
