86 F250 - Ford Truck Enthusiasts Forums
86 F250
Old 05-09-2011, 07:03 PM
heavy86's Avatar
heavy86 heavy86 is offline
heavy86 is starting off with a positive reputation.
86 F250
New guy, been looking around the site a little, lots of good info, now I have a question. Just picked up a new toy over the weekend, 1986 F250 4x4, auto, with a 351w with water in the oil. There is a low mileage engine on craigs out of a '93, the question is will this work with the carb and manifold set-up from the '86? Any input will be appreciated.
Thx
Old 05-09-2011, 08:27 PM
1980 Ford F-250's Avatar
1980 Ford F-250 1980 Ford F-250 is offline
1980 Ford F-250 is starting off with a positive reputation.
I did some reading, and it sounds like all you have to do is change the manifolds. I am not sure if there is anything else needed, but hopefully someone else will chime in if there is.
Old 05-10-2011, 07:30 PM
heavy86's Avatar
Thx, I was hoping they would swap. going to look at the engine saturday. Will probably have more questions as I tear into this beast, been awhile since I worked on an older ford.
Old 05-10-2011, 11:25 PM
Edelbrock 2181 - Edelbrock Performer Intake Manifolds - Application - SummitRacing.com
If you look under the application tab, it says that that manifold will fit 1969-97 351w engines, which tells me that what you are trying to do is possible.
I don't know if it would be too much work, but you could always take the carb manifold with you and compare with the EFI motor.
Old 05-11-2011, 12:33 AM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
You will need to switch out the dizzy too. You will have a serp belt setup if its still on there. You could leave it on there and have that fancy 3g alt too!
Old 05-11-2011, 09:08 AM
heavy86's Avatar
Thx for the input, didn't even think about the serpentine belt, hopefully I can get the engine complete and leave that setup on there. I was looking around the engine last night and there seems to be a lot of vacum hoses unattached and fittings broke off. Does anybody know of or have a vacum diagram I could get a hold of? I'll try to get some pics up in the next day or so.
Got a few new toys today! roy.prue Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 02-16-2011 09:50 PM
New Toy tanman722001 North Carolina Chapter 8 07-26-2009 10:14 PM
Toys dieselpower87 1999 - 2003 7.3L Power Stroke Diesel 24 10-14-2007 03:58 AM
door buzzer disable 75f100 1987 - 1996 F150 & Larger F-Series Trucks 8 11-11-2006 09:10 AM
Another new Toy AXE168 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-25-2006 12:55 PM
Tags
86, f250
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
