1981 F150 Carburator Rebuild - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-09-2011, 05:06 PM
akmikek akmikek is offline
akmikek is starting off with a positive reputation.
I have a 1981 F150 (ranger lariat) with a 302 (canadian model) and i need to rebuild the carburator but can't figure which kit to buy. There is no id tag on the carb. From looking at other pictures it appears to be a motorcraft 2150 without the EGR valve or float bowl vent fitting. Can i just buy a universal kit at oreillys or napa? They have many different kits? The only numbers i can see stamped into the linkage side bottome are what appears to be a 7TAKA and someone scribed a 21 on the top?
Old 05-09-2011, 05:11 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The base of the carburetor has a stamped ID number (like this: E0TF-AA for example). There's no ID number of 7TAKA, it's might be D7TF-AKA.
If you cannot find anything, I'll attempt to find the kit using the Calibration Code Parts Lists.
Hopefully, since it's a Canadian vehicle, there won't be a gaziilion different lists, like there are on US vehicles.
Old 05-09-2011, 05:16 PM
Thanks. I will try that number with the parts store.
1981 302 specs 460jared96 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-15-2015 06:08 PM
1 barrel carburator fomocokid 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-23-2010 03:05 PM
1982 ford f-150 smog question williamsportwrestler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 26 09-24-2009 05:05 PM
4.9 300 EFI to Carburated 1980F15049 Ford Inline Six, 200, 250, 4.9L / 300 7 09-16-2007 05:31 AM
rebuilding a 1 barrel motorcraft for my 300-6 theaxeman99 Ford Inline Six, 200, 250, 4.9L / 300 2 03-16-2002 12:07 PM
Tags
1981, 81, carb, carburator, carburetor, changing, clean, f150, ford, head, line, rebuild, trasmition, type, videos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
