head removal
Old 05-09-2011, 01:28 PM
rustywheel68's Avatar
rustywheel68
rustywheel68 is offline
head removal
'65 F100. i know nothing about the motor's history, other than that the block is a '72.
i've got the intake & exhaust manifolds off, because i'm switching to EFI manifolds, and getting rid of the load-o-matic carb/distributor.
now i'm staring at the bare head, and realizing that if i was ever going to pull it, now is the time.
my question is- what do you recommend? i can see that the backsides of the valves are completely gunked up.
Old 05-09-2011, 02:13 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Hi Rusty,
What are you asking recommendations for? Recommendations on how to remove it? What to do with it when it's off?
Old 05-09-2011, 02:39 PM
rustywheel68
i guess i'm looking for recommendations as to what sorts of things i should be looking for/checking/having done by a machine shop, once i get it off.
the engine actually runs pretty well, but i have no idea how many miles are on it.
Old 05-10-2011, 10:21 AM
rustywheel68
let me rephrase-
if you bought a running truck, but didn't know the history of the engine...and then pulled the intake/exhaust off, and could see that the backsides of the valves are all gummed up:
1. would you go ahead and pull the head?
2. if you did pull the head, what would you do at that point? (milling/new guides, etc)
thanks-
Old 05-10-2011, 10:32 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
If it is not burning oil, and has good power, I think I would leave it and drive it. If the engine has a lot of miles, and the rings are not the best, doing a v.job could cause problems.
If it is burning oil, with poor compression, you could either pull the engine and go through it, or drive it until it drops.
Old 05-10-2011, 10:40 AM
AbandonedBronco
Have you done a compression test on the engine? If your compression's good, it's possible things are just dirty.
But, if you do pull the head, your best bet is to take it to a competent shop that works on heads and have them go over it. They have the specialty tools to measure everything to be sure its all in spec and can give you a much more detailed list of what needs to be worked on.
Although, like F-250 said, if you put a freshly rebuilt head onto a tired engine, the extra compression can cause aging rings to go out.
Old 05-11-2011, 01:09 PM
rustywheel68
thanks guys- i'll shoot for the compression test this weekend.
Old 05-15-2011, 09:25 PM
99hosss's Avatar
99hosss
99hosss is offline
I was in the same boat w\ my 66 240 . I was burning alittle oil , and found all my valve guide seals lying in the head gullies. I did my own valve job with a drill like my daddy showed me, replaced the valve guide seals, and the truck runs better than it ever did. I put a new oil and fuel pump on it also those 240 lower ends will run forever.
brandonwsmith66
02-21-2017 08:05 PM
ljuelfs
1999 to 2016 Super Duty
01-18-2017 02:30 PM
KraZeDav
Exhaust Systems
06-29-2016 07:46 AM
tastyklair
03-01-2004 12:32 PM
donhclark
05-23-2003 01:11 PM
Quick Reply: head removal
