British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
Drive shaft replacement
Old 05-09-2011, 10:23 AM
Charlotte's Avatar
Charlotte
Charlotte is offline
I live on Vancouver Island, I own a 1988 Ford Ranger 4x4 and the drive shaft is a little loose. If it goes, are replacements easy to find? Are they universal across several years, or specific only to my make and year?
Thanks,
Charlotte
Old 05-09-2011, 11:25 PM
Zip's Avatar
Zip
Zip is offline
It almost sounds like ujoints to me. That's a pretty easy fix. If it is the drive shaft I would say that several different years should be the same. I would check autowreckers to see if they have any before looking into a new one.
Old 05-10-2011, 12:41 PM
Snowdrift3r's Avatar
Snowdrift3r
Snowdrift3r is offline
I agree fully Chris, I have never seen a driveshaft fail but have definitely replaceed many U-joints over the years. A pretty easy fix Charlotte, as long as you have a vice to seperate the u-joint from the driveshaft. I would also recommend new joints that have grease fittings.
Old 05-12-2011, 10:38 AM
sedly's Avatar
sedly
sedly is offline
I third that.Its going to be u-joint replacement.
Greaseable is the way to go.
Also Go with a quality u-joint.Moog at the very least.
Old 05-14-2011, 09:45 PM
Charlotte's Avatar
Charlotte
Thanks! Now that I better know what it is, I'm not so freaked out about what to fix when it fails.
Cheers,
Charlotte
Old 06-01-2011, 10:17 AM
Zedrive's Avatar
Zedrive
Zedrive is offline
When a U joint fails while underway it can be catastrofic. I would advise getting it fixed. You as the driver are responsible for what comes flying off your vehicle.
I have had a driveshaft come loose and watched it tumble down the road in my rearview all the time hoping it didn't skip through someones windshield.
Please don't take this lightly get it repaired.
Old 08-09-2011, 12:48 PM
Flatdeck's Avatar
Flatdeck
Flatdeck is offline
What exactly is loose? Maybe the splines need to be greased.
