Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > British Columbia
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: Zip
  #1 (permalink)
Old 05-09-2011, 10:23 AM
Charlotte's Avatar
Charlotte Charlotte is offline
Garage is empty, add now
Charlotte is starting off with a positive reputation.
Drive shaft replacement
I live on Vancouver Island, I own a 1988 Ford Ranger 4x4 and the drive shaft is a little loose. If it goes, are replacements easy to find? Are they universal across several years, or specific only to my make and year?
Thanks,
Charlotte
__________________
Where there's a will, there's a way
  #2 (permalink)
Old 05-09-2011, 11:25 PM
Zip's Avatar
Zip Zip is offline
BC Chapter LDR
1979 Ford Bronco
My Garage
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
It almost sounds like ujoints to me. That's a pretty easy fix. If it is the drive shaft I would say that several different years should be the same. I would check autowreckers to see if they have any before looking into a new one.
__________________
Chris,#12 BS'er/Official Slackmaster #7/AVIDEST WINTER HATER
BC Chapter Member/Leader
JOIN THE BC CHAPTER HERE
  #3 (permalink)
Old 05-10-2011, 12:41 PM
Snowdrift3r's Avatar
Snowdrift3r Snowdrift3r is offline
2007 Ford F-350
Snowdrift3r is gaining momentum as a positive member of FTE.
Belgarrian
Quote:
I agree fully Chris, I have never seen a driveshaft fail but have definitely replaceed many U-joints over the years. A pretty easy fix Charlotte, as long as you have a vice to seperate the u-joint from the driveshaft. I would also recommend new joints that have grease fittings.
__________________
Dwayne, Semi Regular BC Chapter Member
2007 F-350 PSD
2006 Escape for the missus
1965 Rustang project
Thats right... I AM a FORD guy!
  #4 (permalink)
Old 05-12-2011, 10:38 AM
sedly's Avatar
sedly sedly is offline
sedly is gaining momentum as a positive member of FTE.sedly is gaining momentum as a positive member of FTE.
I third that.Its going to be u-joint replacement.
Greaseable is the way to go.
Also Go with a quality u-joint.Moog at the very least.
__________________
Can never seem to stay in the bush long enough!
1976 Ford HiBoy-300I6
1978 Ford Bronco-351M
  #5 (permalink)
Old 05-14-2011, 09:45 PM
Charlotte's Avatar
Thanks! Now that I better know what it is, I'm not so freaked out about what to fix when it fails.
Cheers,
Charlotte
__________________
  #6 (permalink)
Old 06-01-2011, 10:17 AM
Zedrive's Avatar
Zedrive Zedrive is offline
Zedrive is starting off with a positive reputation.
When a U joint fails while underway it can be catastrofic. I would advise getting it fixed. You as the driver are responsible for what comes flying off your vehicle.
I have had a driveshaft come loose and watched it tumble down the road in my rearview all the time hoping it didn't skip through someones windshield.
Please don't take this lightly get it repaired.
__________________
''Keep your words soft and sweet for some day, you may have to eat them'' - Confusius
99 f250 SD, XLT, 4X, LB, 6.8L, ZF5, 4L30 gears 185,000 miles
  #7 (permalink)
Old 08-09-2011, 12:48 PM
Flatdeck's Avatar
Flatdeck Flatdeck is offline
Flatdeck is gaining momentum as a positive member of FTE.Flatdeck is gaining momentum as a positive member of FTE.
What exactly is loose? Maybe the splines need to be greased.
__________________
Greg :: PAA#55
1999.0 F-350 4x4 PSD SRW reg cab, auto, manual xfer case, Warn manual hubs, aluminum flatdeck, VB springs, Predator tuner, 6637, LT285/75R16E Duratracs, 2003 40/20/40, 2005 cupholder, 2005-07 front end, Sirius Starmate 3
Tags
1988, 2006, bronco, drive, escape, f250, ford, loose, replacement, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
