1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
loose fan 2001 5.4
Old 05-09-2011, 09:03 AM
mstiles19's Avatar
mstiles19
mstiles19 is offline
loose fan 2001 5.4
My fan seems to be loose. It is loose where the fan attaches to the shaft. It is kinda hard to see because of the fan shroud being in the way. Is there any way to either tighten it? or can i replace the shaft?
Old 05-09-2011, 01:52 PM
mstiles19's Avatar
mstiles19
does anyone know how to remove or replace the fan/clutch?
Old 05-09-2011, 04:53 PM
mstiles19's Avatar
mstiles19
well I got the fan clutch off. My next question is should i replace the water pump? i have 190,000 miles on it and it has never been replaced.
Old 05-09-2011, 06:14 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
I guess I would replace it since you are in there that far , did ya figure out what was loose on the fan?
Old 05-09-2011, 08:25 PM
mstiles19's Avatar
mstiles19
apparently it looks like the bearing in the clutch was bad, but the clutch worked...I got a new one I am going to do it tomorrow and i maybe do the water pump. I am still on the fence. It was not that hard to get the clutch out and off.
Old 05-10-2011, 07:25 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Unless you really just want to change the water pump, there's not a reason to unless it's not cooling properly, or if it's leaking. My work truck has 260K miles on it now with the original water pump, and it's still good. I've actually never seen anybody wear out a modular water pump, unless they neglected the cooling system and corrosion ruined it.
JL
Old 05-11-2011, 09:42 PM
mstiles19's Avatar
mstiles19
Ok well i got it all done, and all back together. I have two questions now. It seems that my new clutch seems to keep the fan engaged alot. Especially when i first drove it. Do these clutches have a break in period? My other concern is that i still have a slight vibration. The clutch vibration/aweful sound is gone, but there is still some slight vibration. Any ideaa? the vibration seems to be in sync with engine rpms, and worse when in gear then when revved in neutral.
Thanks
KRDiesel
07-22-2023 12:59 PM
greyhound
03-01-2015 05:57 PM
KSRedsoxFan
15
06-11-2010 01:42 PM
country2
08-03-2007 09:11 PM
hotrodfeguy
1983 - 2012 Ranger & B-Series
02-26-2007 08:02 AM
Quick Reply: loose fan 2001 5.4
