dash brake light always on - Ford Truck Enthusiasts Forums
Old 05-08-2011, 05:19 PM
80' ford man55 80' ford man55 is offline
80' ford man55 is starting off with a positive reputation.
hi guys,
Before i took my truck, an 80' f100 with a 302, off the road last fall the brake light in the dash came on. I thought it was because the brakes were terrible. My fronts looked decent, and i changed the backs. My brakes are now great, but the dash brake light is still on.
Anyone come across the same problem or have suggestions? Thanks!
Old 05-08-2011, 05:39 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
It might be the proportioning valve. The haynes manual tells you how to reset it if you have one
Old 05-08-2011, 07:02 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
I agree, porportioning valve could be stuck. Try resetting it, and also bleed the brakes if air could have gotten into the system with the brake repair.
The 1984 year model is the first year that the brake warning light was hooked to the parking brake pedal as standard, so it's almost positive it's not that problem for your 1980, unless someone added it. There was a dealer kit for this before 1984, so just check the parking brake pedal for added wires etc...
Old 05-08-2011, 08:53 PM
I have the manual, i'll have to check it out.
Thanks guys.
Old 05-08-2011, 09:02 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
some of us (me) have used the "remove light bulb" approach, but its not recomended. the posts above are leading toward the proper fix.
Old 05-08-2011, 09:06 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty 6fifty_f1fifty is offline
6fifty_f1fifty is gaining momentum as a positive member of FTE.6fifty_f1fifty is gaining momentum as a positive member of FTE.
The only time mine comes on is when the fluid is low... Edit ***I'm thinking of a Ranger that I used to have.
Last edited by 6fifty_f1fifty; 05-08-2011 at 09:07 PM. Reason: Remembering apparatus re-calibrated.
Old 05-08-2011, 09:10 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
If you want to make sure it is the proportioning valve causing the problem, just disconnect the wire going to the valve. If the light goes out, then that is the problem. It has a plunger that separates the front brake system from the rear. If you have a failure in either system, the pressure difference pushes the plunger off center and grounds the wire which lights the dash light.
Old 05-08-2011, 09:26 PM
Quote:
yeah i thought about it, but i wanted to see how easy the fix would be first. lol
Old 05-09-2011, 03:33 PM
The light is a safety feature. Disconnecting it or making it inoperable is not a wise idea.
There are also insurance repercussions to concider if you get in an accident. Your insurance does not have to pay, and you could be liable for any accident you are in, your fault, or their fault, for tampering with safety equipment.
Old 05-09-2011, 04:14 PM
valid point, fix looks easy enough
Old 05-09-2011, 10:38 PM
ford-lover1995's Avatar
ford-lover1995 ford-lover1995 is offline
ford-lover1995 is starting off with a positive reputation.
i just smacked the bulb with a screw driver untill i get around to fixing it lol
E-brake light on dash. scottddove 1999 - 2003 7.3L Power Stroke Diesel 6 01-31-2016 07:06 PM
Brake Pedal Dash Lights Raymond 1999 to 2016 Super Duty 7 11-08-2012 12:51 PM
E-brake sensor?..... ztodd377 1999 - 2003 7.3L Power Stroke Diesel 2 05-28-2010 04:10 AM
in dash brake warning light todd jo 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-30-2009 09:08 PM
Brake dummy light on dash. Ford51 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 12-11-2006 03:18 PM
Tags
1980, 2007, 250, 82, 86, brake, dash, diesel, econoline, f250, ford, light, reset, suck, truck, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
