4R100 shifting issues
Old 05-08-2011, 02:29 PM
SuperSlimTony's Avatar
SuperSlimTony
SuperSlimTony is offline
I have a 2000 F53 MH with a V10 and 4R100. It has 72K, flushed/changed the transfluid as per a good write up!! I dropped the pan, changed filters, refilled, pulled the cooler line and flushed/filled/flushed/filled. I did that at 60K, shifted fine.
A few weeks ago it started not down shifting out of OD every now and then. Then it stopped downs shifting from OD and threw a P0705 code. It did not down shift from any gear. Then it stared short shifting up. I replaced the TRS (transmission range sensor) with a ford part and it helped the 1-2-3 down shifting some but not 100% and still no OD down shift.
If I hit the OD button on the gear selector it will down shift, and stay down shifted till it needs to up shift, even if i hit the button sooner that it needs..
The fluid id full, nice and red, no burning smell. I checked all the fuses. Now what??
Thanks
T
ps(WE are full time RVer's that travel for my work, so leaving at a shop is out of the question..)
Old 05-10-2011, 07:58 PM
SuperSlimTony
Hello??
Old 05-10-2011, 09:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
You need someone with the right scan tool to read the codes. I suspect that there are codes stored in the PCM that will point where to look. All Ford dealers and any good independent shop will be able to read the codes. The parts stores can't do it.
Old 06-20-2011, 07:30 PM
SuperSlimTony
OK, I had the codes pulled. P1100, P1702, P171&174(had a fuel pump go south), P0705, P1120 & 1125. The guy cleared the codes. 1120 and 1125 is TPS, swapped TPS and nothing. I am looking at P1702 TRS Sensor Intermittent Circuit Malfunction, and the 1100..
Help what next??
<table border="1" cellspacing="1"><tbody><tr><td>P0705
</td> <td> Digital TR
</td> <td> Digital TR circuit failure</td> <td> Digital TR circuits, indicating an invalid pattern in TR_D. Condition caused by a short to ground or an open in TR4, TR3A, TR2 and or TR1 circuits. This DTC cannot be set by an incorrectly adjusted digital TR sensor.</td> <td> Increase in EPC pressure (harsh shifts). Defaults to (D) or D for all gear positions. In (D) position trans, stuck in D or manual 2.</td> <td> WIRING OR DIGITAL TR SENSOR</td></tr></tbody></table>
<table border="1" cellspacing="1"><tbody><tr><td>P0122
P0123
P1120
</td> <td> TP
</td> <td> TP concern</td> <td> PCM has detected an error that may cause a transmission concern.</td> <td> Harsh engagements, firm shift feel, abnormal shift schedule, torque converter clutch does not engage, torque converter clutch cycling.</td> <td> WIRING OR TP SENSOR</td></tr></tbody></table>
<table border="1" cellspacing="1"><tbody><tr><td>P0102
P0103
P1100
P1101
</td> <td> MAF
</td> <td> MAF concerns</td> <td> MAF system has a malfunction which may cause a transmission concern.</td> <td> High or low EPC pressure, incorrect shift schedule. Incorrect torque converter clutch engagement scheduling. Symptoms similar to a throttle position (TP) failure.</td> <td> WIRING OR MAP SENSOR
Old 06-20-2011, 08:00 PM
SuperSlimTony
A little more reading and i cleaned the K&N filter a couple of weeks ago, then the converter stuff started..I'll get some Cleaner, clean the MAF, and retest??
Old 07-10-2011, 11:57 AM
SuperSlimTony
I cleaned the MAF and pulled the Neg Cable for 30 minutes, it ran good for 1 hour then started the engaging and disengaging. Cleaned again and reset, 2 hrs then started, cleaned again, and reset, not past 6 hrs!!! Then the check engine cam back, time to reread codes. Still not down shifting, i was told it is a solenoid pack in the trans. Still looking to find some more info??
Thanks
t
Old 07-10-2011, 05:19 PM
Mark Kovalsky
The more info would come from reading the codes again.
Tesknox
1999 to 2016 Super Duty
05-07-2023 05:45 PM
mdula
35
11-03-2018 09:18 AM
3000gtman
45
10-21-2016 08:57 AM
entropyeng
05-03-2016 08:21 AM
YoGeorge
04-14-2008 09:14 PM
Quick Reply: 4R100 shifting issues
