Help! My speedometer quit working - Ford Truck Enthusiasts Forums
Old 05-08-2011, 12:58 PM
code_red's Avatar
code_red code_red is offline
code_red is starting off with a positive reputation.
I have a 1995 F150 , 302 , 5 speed trans with 119,000 miles on it. My speedometer quit working on me about a week ago and I avnt a clue where to look 1st for fixing this problem. Any help will be gratefully appreciated, thanks (Oh this is my son truck)
Old 05-08-2011, 01:00 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
First thing to do is check ALL of your fuses.. The speedometer is electronic.. Remember there is 2 fuse boxes..
Old 05-08-2011, 02:14 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
If fuse #8 & #18 are good then:
NOTE:
Only wiring harness end of connector is to be probed.
Connect Digital Volt-Ohmmeter to Pin 4 (speed in +) and Pin 5 (speed in -).
Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)?
OR,
If available, a frequency counter may be connected to Pin 4 (Speed in +) and Pin 5 (Speed in -).
Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)?
OR,
If neither a voltmeter nor frequency counter is available, vehicle speed control may be used as a good indicator. If it works normally, then the speedometer module is at least receiving a speed input signal and the wiring and sensor can be assumed to be good.
A wiring diagram:
NEED HELP b-series Ranger & B-Series 7 06-27-2015 09:48 AM
Speedometer Turmand Ranger & B-Series 8 03-15-2015 11:54 AM
Speedometer works, oedometer doesn't???? chuckj5 Explorer, Sport Trac, Mountaineer & Aviator 2 03-10-2015 05:17 AM
Speedometer problems 50trucking 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-23-2014 04:13 PM
E250 2003 speedometer problem Tom2003 1968-2013 Full Size Vans 4 08-11-2013 12:48 PM
Tags
1997, 1999, 2004, 4x4, expedition, f250, f53, ford, motorhome, quit, quits, speedometer, stop, stopped, v10, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
