frame work - Ford Truck Enthusiasts Forums
frame work
Old 05-08-2011, 04:21 AM
fordcaver91 fordcaver91 is offline
fordcaver91 is starting off with a positive reputation.
frame work
Ok i got a 89 f150 ex-cab short bed. i was thinking about putting a long bed on it. To do so i have to lengthen the frame a little before the rear tires. How hard would it be to do this? It also has to be as strong or stronger than stock. What else is there to do? thanks.
Old 05-08-2011, 08:09 AM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
It can be done. If you are doing that then Z-cut the frame, weld together and then fish plate the joint. If done right it will be stronger than original..
other option is go to a JY and pull a long bed frame. clean it up and then just transfer everything over to "new" frame.
Bed to frame ground thunderbirdcakes 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-30-2013 09:55 AM
74 & 76 frame compatibility Canus 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-12-2013 07:20 PM
How do I shorten my 8' bed randrford 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-10-2008 12:34 PM
Frame rust. Stanstruck Paint & Bodywork 1 06-28-2004 04:48 PM
Post-80's frame question Acrasia 1987 - 1996 F150 & Larger F-Series Trucks 9 02-28-2003 07:03 PM
Tags
1994, 87, bed, cab, cutting, f1, f150, ford, frame, long, shortbed, specs, truck, trucks, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
