Anyone got torque curve graphs for 300 vs. 351? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-10-2011, 07:38 PM
mako5972 mako5972 is offline
mako5972 is new and has a neutral reputation at this point.
Like I said before, why not just install a Comp Cams 4X4 cam or an RV cam. Low end grunt is what you want. Those graphs proved that the 351 Windsor is the better choice. Gearing can be used as a "torque multiplier", think of a granny gear on some of the standard transmissions. As a matter of fact, I know that there are threads somewhere on this sight about doubling up transfer cases for some real grunt.
Old 05-10-2011, 10:08 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The only reason the 300 feels torquey is because it makes NO horsepower, and there aren't many options available to help it produce more. The 5.8 outperforms it stock and will flat out embarrass it with a couple simple upgrades.. the Crane 444232 and a set of longtubes. Any one of you guys that's got an early flat tappet 5.8 that hasn't done this swap yet has no idea how much potential this motor has... so get on it already.
Old 05-10-2011, 10:19 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Quote:
Dude,trust me 300s can provide HP as well as more torque if you build them correctly. If not, they wouldn't be used in drag racing.
Old 05-10-2011, 11:19 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
Quote:
Yeah, but at what cost? The 351w can be built on the cheap side and blow the 300 away at anything if both were built with the same $$$.
I think i spent around 2k for my motor. That includes a freshly rebuilt shortblock. I tell ya what... i'll never go back to a 300 or even a stock 351w.
Old 05-11-2011, 12:19 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
How many do you see drag racing?
Approx 300 horse at the flywheel, 5700 rpms at 134 mph. Does this look like a good truck engine?
Front Engine Dragster with Six Cylinder Power rips 9.34! | MyRideisMe.com
Horsepower Calculator from 1/4 mile ET and Trap Speed - DragTimes.com
Old 05-11-2011, 12:37 AM
82_F100_300Six's Avatar
82_F100_300Six 82_F100_300Six is online now
82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.
I can relate an experience which opened my eyes a little. I have an old (God Forbid) chevy C20 3/4 ton truck with the big eight lug rear end that I use as my "boat ramp truck". ie I can tow my boat to the ramp and leave the truck at the ramp for a week and not worry about some A-hole backing into it or breaking into it.
A few years back I rebuilt the automatic transmission to shift nice and crisply (is that a real word?). I also did something per the instructions to the servo or valvebody that would make it shift late into third gear, so it doesn't dump into third gear at 20 mph.
I built a stroker motor and put some 64cc Dart Iron Eagle heads that I had blended up nicely and tapered the valve guide bosses. I had a little too much compression so I put a Lunati cam in it to bleed some off. Turned out to be the biggest turd ever. The SOB would start knocking at the mere sight of a hill, bridge, or overpass coming up.
Recently I sold a little four door 70 Nova that I built a 305 for. I had spent a week at work on nights smooting out the intake and exhaust ports on those stock heads, and then put the smallest crane energizer cam they had in it. On top I had an old Weiand Stealth dual plane and a Carter AFB, and dynomax headers. Sucker had the smoothest idle and maniflold vacuum for days on end.
I got the idea to pull the POS stroker 383 out of the 3/4 ton truck and put the little 305 in but was worried that it would not be enough for the truck. Went ahead anyway a day and a half later I had one motor out and the other in. All I can say is wow. that little smooth idle non-lopey no overlap 305 bitch slaps that big truck around in any way it wants to. Towing a 20 foot center console up and down grades or flat out highway cruising and smokes the 383 in every aspect, including gas mileage and hot starting which is no longer an issue.
so thats a little long winded but my point is you can maximize efficiency and put power where you want it, let em breath, all they need is air and fuel.
I'm a big fan of the 300 six but I would think that a 302/351 or 400 allowed to breathe and built for torque would make for some happy days for you. If you have a carb and no computer its gonna be pretty easy in my opinion.
Old 05-11-2011, 06:20 PM
Check out the guys on www.fordsix.com
They got some drag cars with em.
But with any engine...you can make it a monster....if you have the time and money.
With a truck I rather have torque.....if you want HP just buy you a race car. HP is good too but Torque is where it is at for a truck.
Old 05-11-2011, 06:42 PM
ErrorS ErrorS is offline
ErrorS is starting off with a positive reputation.
how much of a difference will an RV cam make? I know little to nothing about building motors. Like, I dunno where the torque even comes from or why this curves high so late in the game when a motor like the 400 has so much more torque at the lowend, and the 400 is starving in stock form.
is it all in the cam? what upgrades should I be looking at? Like I said, i don't care about horsepower, I don't care about torque above 3000RPMs really. I just want the motor to get me moving and keep me moving at low RPMs. Should also really help my gas mileage.
I'm also not sure about flow. I increased 'flow' on my 400 and if anything, it made it feels worse.
Heck, I might even pass on a rebuild for the time being and try an RV cam and see if it helps me at all.
Old 05-11-2011, 07:12 PM
Get some headers, cam/lifter set (make sure they will work for your heads), flat top pistons, heads ported and polished, double roller timing chain, aftermarket intake and a good carb.
Old 05-12-2011, 09:38 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
The 460 was not an option on the F150 after 1979.
Old 05-12-2011, 10:16 AM
Go to the Comp Cams website. Get their phone number, and give them a call. Tell them what you have, and what your needs are. They want customers, and they want customers to be HAPPY. They will help you.
Old 05-13-2011, 03:58 AM
Thanks guys.. gonna call comp cams and see what they have to say. I'm sure I wont be the only moron who has called asking basic questions.. Though, after some reading it seems as though cams can make pretty extreme changes in your curve. I was reading about more extreme cams for racing and stuff, but some were giving a stock motor 50+ torque at certain RPMs and dropping it a couple dozen horsepower. That's sorta what I'm wanting.
and Manfred, this is an EFI engine, speed density, gonna keep it that way. I'm going to look into a MAF swap or getting some tuning done so I can run the cam I want and possibly go for a bigger intake. I've read some first hand experiences where guys couldn't get their truck running right just after swapping an intake in a speed density setup. If it is going to be THAT limiting to me, especially if I can't use the exact cam I want, then I'm going MAF.
I'm also not a fan of headers. They're 'cool', they just seem to cause problems though. I already hate how close my plugs are too my manifold on this motor, I can't imagine how much I would hate headers. Don't really need it to open up that much for torque at low RPMs anyways.. a better intake, mainly for clearance (i have a lot of hood space, my intake could be taller) is definitely in my future.
  #28
Old 07-01-2011, 09:41 AM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
i say go for an engine swap, but, BUY a donor truck, you get the engine you want, now you have drivetrain,wiring,ecm, dash everything for the price of the donor. I'm thinking about doing it with my project truck
An resell what you dont use
  #29
Old 07-01-2011, 11:32 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
The only reason the 300 feels torquey is because it makes NO horsepower.
They feel torquey because they make a lot of torque.
  #30
Old 07-01-2011, 11:40 AM
Quote:
Just not as much as a 351w....
1978 Ford Econoline Club Wagon Help!! Weldermike92 1968-2013 Full Size Vans 3 08-31-2016 01:28 AM
rpm / torque graph for fe 390 / 360? eclectix 1967 - 1972 F-100 & Larger F-Series Trucks 16 09-04-2015 04:20 PM
Looking for HP/Torque graphs for my 89 351W Blue Rebel Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 19 08-13-2010 11:14 PM
V10 torque/hp graphs-numbers Rancheroracer Modular V10 (6.8l) 38 04-25-2010 11:15 AM
'04 6.0 boost curve chart or graph? Packard V8 6.0L Power Stroke Diesel 1 09-16-2009 06:29 PM
Tags
1978, 2004, 300, 351, 351m, 370, 460, chart, curve, expedition, f150, ford, power, specs, straight, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
