1992 to 1995 f250 wiring harness swap - Ford Truck Enthusiasts Forums
Old 05-07-2011, 09:55 PM
shaggy_32003's Avatar
shaggy_32003 shaggy_32003 is offline
shaggy_32003 is starting off with a positive reputation.
So my 1995 F250 had a minor fire roughly a year ago that caused some of my wiring harness to be destroyed. After searching for a replacement one with no results I decided to take the harness out of my 1992 project 250 to replace it and just replace the 92's when I finally found one. Both trucks are 250s, xlt, 4x4, automatic, and 351s. I have both harness out of the trucks and I laid them side by side to make sure they are both the same except for one part. I need to know if I can still make this swap work and how. Any help would be greatly appreciated. Thanks.
<a href="http://s1102.photobucket.com/albums/g447/shaggy_32003/?action=view&amp;current=Photo_5847722A-B82E-C9F2-B5DE-916CA1CE5E60.jpg" target="_blank"><img src="http://i1102.photobucket.com/albums/g447/shaggy_32003/Photo_5847722A-B82E-C9F2-B5DE-916CA1CE5E60.jpg" border="0" alt="Photobucket"></a
<a href="http://s1102.photobucket.com/albums/g447/shaggy_32003/?action=view&amp;current=Photo_526580B9-288B-1EF2-5945-6A8075CD8549.jpg" target="_blank"><img src="http://i1102.photobucket.com/albums/g447/shaggy_32003/Photo_526580B9-288B-1EF2-5945-6A8075CD8549.jpg" border="0" alt="Photobucket"></a>
What is this part?
<a href="http://s1102.photobucket.com/albums/g447/shaggy_32003/?action=view&amp;current=Photo_664A1D7A-E891-0648-5566-78C2EBBB9EFD.jpg" target="_blank"><img src="http://i1102.photobucket.com/albums/g447/shaggy_32003/Photo_664A1D7A-E891-0648-5566-78C2EBBB9EFD.jpg" border="0" alt="Photobucket"></a>
The above picture is of the connector from the 1992.
<a href="http://s1102.photobucket.com/albums/g447/shaggy_32003/?action=view&amp;current=Photo_0B4B3D58-ABB2-808A-86C3-E203A460221E.jpg" target="_blank"><img src="http://i1102.photobucket.com/albums/g447/shaggy_32003/Photo_0B4B3D58-ABB2-808A-86C3-E203A460221E.jpg" border="0" alt="Photobucket"></a>
This photo is of the connector from the 1995.
Old 05-08-2011, 09:54 AM
Bumpity bump
Old 05-08-2011, 10:09 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The part with the circle around it is the Speed Control Servo/Amplifier Assembly.
In 1992 they used a vacuum Speed Control and 1993 on they used Electric.
This photo is of the connector from the 1995.:
C216 Speed Control Servo/Amplifier Assembly
The above picture is of the connector from the 1992.:
C1018, Speed Control Servo
Old 05-08-2011, 02:26 PM
So I'm wondering if I need to hook that up? Can I just leave the cruise unhooked and never use cruise?
Old 05-08-2011, 03:21 PM
subford's Avatar
I do not see why not.
how would yall fix this? dieseldodgeguy 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-27-2014 09:40 PM
my 76 swb 2wd dilemma dieseldodgeguy 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-17-2013 11:19 AM
My head porting Labhound Ford Inline Six, 200, 250, 4.9L / 300 6 10-02-2012 06:29 PM
before 'n after f-250 rear lift blocks loosenutNH 1999 to 2016 Super Duty 14 11-23-2011 09:57 PM
Why Fords need to be tough!! KRDiesel New Mexico Chapter 16 05-23-2008 09:38 AM
Tags
150, 1979, 1992, 1995, 87, 93, amplifier, f150, f250, ford, harness, rv, servo, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
