m5od shifter on a zf5, can i do it. - Ford Truck Enthusiasts Forums
Old 05-07-2011, 07:00 PM
79 f-150 guy's Avatar
79 f-150 guy 79 f-150 guy is offline
79 f-150 guy is starting off with a positive reputation.
my buddy has a hurst shifter for on a half-ton ford m5od, i was wondering if it will fit on my zf5 in my f-250.. i wasnt sure if they shard the same shifters or not, but if they do i wanna grab it for my truck.. thanks
Old 05-07-2011, 07:11 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
I don't think it will work.
Old 05-07-2011, 07:22 PM
ya i lookied in my books a minute after posting, they look differant.. dam, geuss im up **** creek on getting a good shifter for a zf, does anyone know if i can atleast get a new factory one or a rebuild kit.. thanks
Old 05-08-2011, 08:53 AM
EPNCSU2006's Avatar
What's wrong with the one you have now, is it just really sloppy and worn? There are a couple of nylon bushings in the shift tower, maybe they are worn. I would think you can still get those from Ford.
ZF5 MOD F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-29-2016 03:33 PM
M5OD ZF Conversion - Shifter Bolts HEpTJJ 1987 - 1996 F150 & Larger F-Series Trucks 2 07-22-2014 11:06 PM
Should an SROD 4x4 tranny be on the "to hunt for" list? reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 36 04-08-2014 08:17 PM
zf5 short throw shifter KevinC. 1994.5 - 1997 7.3L Power Stroke Diesel 14 05-22-2009 08:43 PM
Shift Knob Removal M5od Trans 4.2W/GEARS Clutch, Transmission, Differential, Axle & Transfer Case 3 03-16-2004 11:07 PM
Tags
bushing, bushings, drivability, f150, ford, kit, kits, m50d, m5od, nylon, picture, rebuild, shifter, speed, zf, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
