How much oil? - Ford Truck Enthusiasts Forums
How much oil?
Old 05-07-2011, 06:56 PM
BigBlue92 BigBlue92 is offline
BigBlue92 is starting off with a positive reputation.
How much oil?
I have a 1997 F250 HD with the 351. Was wondering how much oil the engine holds. Everywhere I look it's somethin different. One place says 5 quarts while the other says 6. Which one is it?
Old 05-07-2011, 07:04 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Depends on oil filter, pan, etc.....They usually take 5....Add a qt. filter, it'll need 6....
Old 05-07-2011, 07:10 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
6 quarts with a filter change
Old 05-07-2011, 07:31 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
6 w a filter
Let's talk about OIL PUMPS Greywolf Performance & General Engine Building 3 05-24-2015 12:16 PM
Crankcase ventilation re route superduty1967 6.0L Power Stroke Diesel 1 02-06-2015 06:25 AM
400 oil capacity clhart426 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-25-2010 11:36 AM
Oil Change... how much ???? RussB 2004 - 2008 F150 12 04-01-2009 12:11 PM
How much ATF in the Torque converter???? tesserra Clutch, Transmission, Differential, Axle & Transfer Case 4 04-01-2008 02:13 AM
Tags
1971, 1997, 250, 360, 406, 67l, 73, f250, f350, ford, gas, muck, oil, quarts, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
