A/C problem on 96 F150 - Ford Truck Enthusiasts Forums
Old 05-07-2011, 05:45 PM
jedijeb jedijeb is offline
jedijeb is starting off with a positive reputation.
I have a 96 F150 I have had since new and finally this spring the A/C has stopped working. I figured maybe it had leaked a little Freon so I got a can from O'reiliy's (with the gauge, never try it without one). I stick the gauge on the low side by the dryer and it reads 109psi! I guess it isn't low, so before I take it in I was wondering if it is just a blocked dryer or maybe something else. Don't want to be suckered by someone since I don't know any of the mechanics in this area well yet. The pump doesn't engage so I think the overpresure sensor is working. Thanks for any help,
Old 05-07-2011, 06:26 PM
Diesel-N-Bucket Diesel-N-Bucket is offline
Diesel-N-Bucket is starting off with a positive reputation.
I would check your fuse first. Then check the wires going to the clutch on the comprssor using a meter or test light. If no power there, then could be a switch. With your system not running, the freon will equalize thoughout the system. It could be various switches from you selector on the dash, high pressure switch, and the low pressure switch being in open condition.
I'm not an expert on automotive equipment, but I do commercial HVAC/R for a living.
Old 05-07-2011, 09:35 PM
redlightning93's Avatar
redlightning93 redlightning93 is offline
redlightning93 is starting off with a positive reputation.
I would assume that your compressor was not turning when you put the gage on it. A reading of 109 was just a static pressure and is usually about the same as the temps under your hood so if the engine had been running and the underhood temps were high then that reading was about right. This reading has no relation to the amount of refrigerant in your system. You will need to jump the wire at the low pressure switch on your accumulator to make your compressor run and then see what your reading is. Do not let the compressor run very long if is low on refrigerant as damage will occur.
You need a set of a/c manifold gages that will give you an accurate low and high reading so you really know exactly what is going on. If you do not have gages they can be rented at your local Autozone. You pay for them and when you bring them back they return your money.
Old 05-08-2011, 12:07 AM
Thanks for the info everyone. I wasn't sure what the static pressure was supposed to be, the Haynes manual didn't list it. I didn't want to hook up the can if the pressure was that high is why I checked it first. The engine was running and I had just gotten home so it was warm under the good.
A/C question 91 Ranger dino360 Cooling, Heating, Ventilation & A/C 3 09-10-2016 03:18 PM
Repairing my A/C system. A couple quick(?) questions Vic93 Cooling, Heating, Ventilation & A/C 3 08-01-2013 05:55 PM
F250 AC Compressor Clutch not Cycling VA250SD Cooling, Heating, Ventilation & A/C 3 05-12-2012 11:58 AM
A/C clutch cycle E150 Cooling, Heating, Ventilation & A/C 1 07-29-2008 07:23 PM
Receiver/Dryer Replacement dvf2001 Cooling, Heating, Ventilation & A/C 1 08-22-2005 07:46 PM
Tags
150, 1987, 1996, 2004, 2010, 96, ac, f150, ford, issues, jumper, older, problems, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
