Vapor Lock in a 302?
Old 05-07-2011, 01:54 PM
1stgenf250's Avatar
1stgenf250
1stgenf250 is offline
Having problems with an 87 F250 with a 302. When it's warm out the truck will run fine for about 20 - 30 minutes then it will stall. Changed distributor, coil, and computer. Does a 302 have vapor lock issues? Fuel pump maybe? It doesn't matter which fuel tank I run on, the problem persists.
Thanks,
Daryn
Old 05-07-2011, 02:09 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
You may have in tank fuel pump issues, these low pressure pumps fail often.
Old 05-07-2011, 02:45 PM
1stgenf250's Avatar
1stgenf250
how possible is it for both low pressure pumps to fail?
Old 05-07-2011, 09:34 PM
96onefifty's Avatar
96onefifty
96onefifty is offline
Does it fire right back up or does it have to cool down first? sounds more like the Ignition Module located on the bottom side of the distributor to me.
Old 05-08-2011, 07:08 AM
1stgenf250's Avatar
1stgenf250
I replaced the ICM when I rebuilt the distributor. It does have to cool down before it will restart though.
Old 05-10-2011, 02:18 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
In the 90s my 88 F150 with the 302 plus dual tanks had the same issue.
I replaced all items related to the fuel system. FPR, relays, filter, Hi Press fuel pump and finally the intank low press pumps.
These pumps were easily damaged by water in the gas tank.
These LP pumps would build up enough fuel pressure to feed the HP pump, but
the lack of volume from the LP pumps would cause the truck to stall.
It may not be your problem, but it is something to look into.
And yes, both pumps failed at the same time.
elkhunter
23
07-28-2023 10:48 PM
jarheadd87
1947 and Older Ford Trucks
08-19-2020 06:51 AM
joesluckyseven
15
07-27-2014 05:51 PM
eriklane
01-31-2011 10:29 AM
AbandonedBronco
24
10-12-2009 12:17 PM
Quick Reply: Vapor Lock in a 302?
