Vapor Lock in a 302? - Ford Truck Enthusiasts Forums
Old 05-07-2011, 01:54 PM
1stgenf250 1stgenf250 is offline
1stgenf250 is starting off with a positive reputation.
Having problems with an 87 F250 with a 302. When it's warm out the truck will run fine for about 20 - 30 minutes then it will stall. Changed distributor, coil, and computer. Does a 302 have vapor lock issues? Fuel pump maybe? It doesn't matter which fuel tank I run on, the problem persists.
Thanks,
Daryn
Old 05-07-2011, 02:09 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
You may have in tank fuel pump issues, these low pressure pumps fail often.
Old 05-07-2011, 02:45 PM
Quote:
how possible is it for both low pressure pumps to fail?
Old 05-07-2011, 09:34 PM
96onefifty 96onefifty is offline
96onefifty is starting off with a positive reputation.
Does it fire right back up or does it have to cool down first? sounds more like the Ignition Module located on the bottom side of the distributor to me.
Old 05-08-2011, 07:08 AM
Quote:
I replaced the ICM when I rebuilt the distributor. It does have to cool down before it will restart though.
Old 05-10-2011, 02:18 AM
khadma's Avatar
Carpenter Local 745
In the 90s my 88 F150 with the 302 plus dual tanks had the same issue.
I replaced all items related to the fuel system. FPR, relays, filter, Hi Press fuel pump and finally the intank low press pumps.
These pumps were easily damaged by water in the gas tank.
These LP pumps would build up enough fuel pressure to feed the HP pump, but
the lack of volume from the LP pumps would cause the truck to stall.
It may not be your problem, but it is something to look into.
And yes, both pumps failed at the same time.
Vapor Lock? joesluckyseven 1987 - 1996 F150 & Larger F-Series Trucks 15 07-27-2014 05:51 PM
1940 Ford Pickup...Vapor Lock jarheadd87 1947 and Older Ford Trucks 4 11-11-2013 09:40 AM
Vapor Lock - How do I prevent it? elkhunter 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-03-2012 09:07 AM
1986 351w vapor lock/return line eriklane 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 01-31-2011 10:29 AM
"Vapor Lock" in 85 degree weather, what's up? AbandonedBronco Ford Inline Six, 200, 250, 4.9L / 300 24 10-12-2009 12:17 PM
Tags
1997, 302, 50, 97, cylinder, engine, f150, fixes, flathead, ford, fuel, liter, lock, stall, vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
