1989 F-150 302 Wont stay running - Ford Truck Enthusiasts Forums
Old 05-07-2011, 01:36 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
So guys, I've got my dad's 1989 F-150 302 w/4 spd manual....When it gets started after it sits for a while....it will shudder and start to stall, if you give it some pedal it revs up and acts fine, if you let off it starts shuddering and you can watch the RPM's go from bout 750~800 down to 500 and below....then it will stall and die....any ideas whats causing this?
Old 05-08-2011, 01:14 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Ford Fuel Injection Idle Air Bypass (IAB) Here is what I would look at first. You can clean it with carb cleaner but don`t get any cleaner in the electrical parts.
Also, from the list on the right of that page, click on Self Test and check for any trouble codes.
Old 05-08-2011, 02:35 PM
Aune163rd's Avatar
Wow lol, i bet that is the problem too, cause after you run it consistently for a few days, it wont do it anymore cause your moving that damn spring. thanks Lazy K
1989 f150 runs rough when started hot 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 1 02-28-2017 07:10 PM
Vacuum at FPR reads 11 hossyazza 1968-2013 Full Size Vans 26 04-25-2016 02:23 PM
1996 f250 stalling problems dougal3434 1987 - 1996 F150 & Larger F-Series Trucks 5 03-06-2016 01:57 PM
E4OD shuddering badly in lockup? quaddriver 1987 - 1996 F150 & Larger F-Series Trucks 20 11-01-2011 02:24 PM
Trannsmission Shudders 429unibody 2004 - 2008 F150 60 04-06-2011 06:52 PM
Tags
150, 1978, 1989, 2000, 302, 50, 77, f150, ford, litre, running, smoking, stay, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
