replacing auto hubs - Ford Truck Enthusiasts Forums
replacing auto hubs
Old 05-07-2011, 01:18 PM
tmg2072 tmg2072 is offline
tmg2072 is starting off with a positive reputation.
replacing auto hubs
I got a 1994 ford f150 with auto locking hubs and the push buttom 4x4 on the dash i was wanting to replace them with manual hubs. I heard from some people you don't need a kit to do this but the local mechanis says he has done them before and you need one has anyone done this before. Any info would be appreciated.
Old 05-07-2011, 06:39 PM
jedijeb jedijeb is offline
jedijeb is starting off with a positive reputation.
I replaced mine back in 99 I think, and if I remember correctly I just bought Warn replacement hubs and everything was included. It isn't too difficult, just watch for the big spring when you remove the hub, it can send it flying right at you if you are not careful. My auto hubs would start sounding like someone spinning a ratchet while doing down the road. Took it in under warranty and they could never fix it or make it fail while they had it. Once the warranty was out I just replace them with manuals, been working fine ever since.
Old 05-07-2011, 09:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
you need the locking style nuts yes.if you don't use them,your wheel bearings will loosen up eventually and ruin your new hubs........worse if you don't catch it in time!
make sure you get the correct locking parts w/manual hubs or she'll come undone on you.
pretty much the best mod you can do to is ditching them auto locking cheap things with a good set of manual lockers.you'll never look back and never give a care that you need to get out and turn hubs manually,because they just plain work.
Old 05-07-2011, 11:47 PM
Thanks this info will help alot
front hubs dhag911 6.0L Power Stroke Diesel 14 12-12-2013 04:00 AM
Rebuilding auto locking hubs? scurbiedog 1978 - 1996 Big Bronco 18 11-27-2011 05:35 PM
Swapping manual hubs for auto hubs Smiley Pete 1999 to 2016 Super Duty 16 08-19-2007 09:56 PM
serviceing auto locking frt hubs? Powerstroken7.3 Offroad & 4x4 9 03-26-2007 08:38 PM
Hub Conversion Question stuckinthesnow 1987 - 1996 F150 & Larger F-Series Trucks 1 04-15-2004 12:15 PM
Tags
1993, 1996, 97, auto, changing, f150, f250, ford, fordf150, hubs, replace, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
