timing cover leaking coolant
Old 05-07-2011, 10:01 AM
F3fitty's Avatar
F3fitty
F3fitty is offline
My timing cover is leaking fluid between the cover and the block. What is involved in replacing this gasket. I am getting ready to sell the truck so I just want to fix the leak. Its a pretty steady leak (drip--drip--drip) in the driveway... and i can see it bubble when i crank up the truck.
How much of a PITA is replacing this gasket?
Old 05-07-2011, 06:38 PM
92 Black Nite's Avatar
92 Black Nite
92 Black Nite is offline
I had to do the same thing. You have to pull the pump, balancer, and timing chain cover. While I was in there, I replaced the timing chain. Not hard to do; just takes a little time. You may or may not want to do the timing chain because you're selling it, but that's up to you.
Old 05-07-2011, 07:32 PM
86F150302's Avatar
86F150302
86F150302 is offline
Dont know about a 460 but I did mine on my 351 a while ago.
Not hard just a PITA.
My trucks present to me.. - The National Lightning Owners Club Inc
Old 05-07-2011, 10:40 PM
F3fitty's Avatar
F3fitty
F3fitty is offline
so you dont have to drop the whole oil pan?
Old 05-08-2011, 12:02 PM
92 Black Nite
Now taking down the oil pan is a Pain in the A$$.
I have done it for a friend to replace his timing chain and pulling the oil pan, it is to say the least a real treat.
But when I did mine I asked a local ford tech, he said to take out the front 6 bolts in the pan and loosen the rest just so you can pull the pan down enough to clear the timing chain cover. I did it and wiped off as much as I could on the gasket and put a thin coat of sealer and was Ok with no leaks when done. Just take it easy pulling down the pan as I said just enough to clear the TC cover.
Old 05-08-2011, 03:41 PM
F3fitty's Avatar
F3fitty
F3fitty is offline
Awesome. thanks for your help.
Byoung Oh
1983 - 2012 Ranger & B-Series
03-10-2017 05:26 PM
kdaug5
19
01-06-2017 06:47 PM
klle5
03-23-2016 04:52 PM
DougJ_1997PSD
19
09-25-2015 11:00 AM
j.bluhm
12-16-2005 12:05 AM
Quick Reply: timing cover leaking coolant
