1987-91 Vs 1992-97 clutch pedal assembly. - Ford Truck Enthusiasts Forums
Old 05-07-2011, 04:49 AM
kjgibson2's Avatar
kjgibson2 kjgibson2 is offline
kjgibson2 is starting off with a positive reputation.
I'm getting an 1989 F-250 Ext Cab with an automatic trans, I'm converting to a manual so I'll need the clutch pedal assembly. I and going to update the cab and put in the 1992-97 dash etc. I was hoping someone would be able to tell me where the assembly bolts to so I know if I need the newer assembly or the older assembly. Thanks
clutch pedal assembly Natcox012 1987 - 1996 F150 & Larger F-Series Trucks 1 03-19-2015 09:39 AM
92-97 dash pad Brettboat 1987 - 1996 F150 & Larger F-Series Trucks 9 09-09-2013 04:55 AM
1992-97 wiring harness scott79 Ford Truck Parts for Sale 1 08-06-2013 06:07 AM
New 1996 Bronco Owner snatchss454 New Member Introductions 4 07-06-2013 01:20 PM
1992-97 F250 Crash Test Ratings Mr Personality 1987 - 1996 F150 & Larger F-Series Trucks 6 02-23-2004 01:29 AM
Tags
1987, 1989, 1992, 1996, 1997, assembly, clutch, diagram, diesel, f250, ford, pedal, pickup, ranger, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
