So here we are 3 years later.....
That being said, the Tundra is more "Made in America" than the F-Series trucks are... by roughly 10% if I remember correctly. It aint a bad vehicle, but it's NOT a heavy duty truck.
And Nissans are junk.
1. Ford (duh)
2. GM
3. Nissan
10. Chrysler
There is no 4 through 9. Just didn't seem fair to imply that Chrysler trucks are almost as good as Nissan.
Reasons- Ford has lower "life cycle" costs than any other brand, and it does its job well for a long time. That they are integrated into a line of full-size and medium-duties is a plus. Plus for cheap parts and use of the same parts for different models.
If you look at Ford and GM trucks side-by-side, especially older ones, they are mechanically similar in many ways. But GM polishes parts no one will ever see, and simultaneously makes some very important parts without much thought as to how they will wear. Styling a plus, ripping off the US a minus.
Nissan- Reliable, gets the job done at the end of the day, and cheaply. But it can't do what a Ford can do. Minus for gaps in full/medium lineup.
Chrysler- Almost every single part wears through or rusts out 100' from the dealer's lot. They look badass but take off the sheetmetal and it's just two lips with hair around them. And the fuel economy is not a plus.
2. GM
3. Nissan
10. Chrysler
Toyotas and Nissans are LIGHT duty trucks. Not meant for hauling anything but small bed loads and light duty trailers. They are "trucks" with the suburban dad in mind, not really a construction or heavy hauling type truck.
Then the cams started breaking and taking out engines.
Then the bed bounce
Then the bolted together frame
Then the suspension recall
In 5 years of living in MN, I have yet to see a tundra with a snow plow on it. I've seen everything from wranglers and rangers to f700s with plows on them.
As far as I'm concerned, The tundra is a slightly faster Ridgeline.
It's a bad vehicle. When the tailgate problems came up, they claimed it's only rated for 200 lbs. What do most owners do, take a running jump to get in the bed? How is that even remotely acceptable?
Then the bed bounce
Then the bed bounce
I wouldn't.
Ford, GM, and Fiat (Dodge/Ram) sell mostly light duty trucks. Real businesses, including construction use plenty of Tacomas, Rangers, and even minivans. Ford's Transit Connect is starting to take over the service market.
Out here, its the suburban mom or dad that is most likely to drive the F-350 diesel, while a real construction business uses the right tool for the job, even if its an old Windstar minivan.
Personally I'd own a Chebby before I owned a Dodge or "Toy" truck. At work all the track guys have Fords (4) or Chevys (2)...no Dodges or other brands. The Fords have gotten a bad rap because of the International design issues in past trucks...but the company keeps buying 'em and they keep running 'em. You want to torture test a truck? Hand it over to a railroad and tell 'em to use it. Tires are the only thing...no matter what brand, that don't stand a chance from the get go.
No really, tell how you feel about the Chrysler/Fiat truck
I'd like to see a photo of it just for the humor. Being from Arkansas...only the state has plow trucks; and they're just a handful of dump trucks with attachment points up-front. Everyone else uses motor graders, front end loaders or farm tractors if/when it snows. I still remember the first time I went on a plow run with my uncle in Michigan (mid '80s)...he was using a F250 clearing driveways. It was an experience to say the least.
4tl8ford
21
12-30-2015 10:30 AM
DerekShiekhi
General Automotive Discussion
10-15-2015 09:49 AM
edtahaney
1983 - 2012 Ranger & B-Series
09-08-2015 06:07 PM
79 shortbed lover
01-19-2011 11:58 PM
