Finally starting project... Need help (long read) - Page 2 - Ford Truck Enthusiasts Forums
Old 05-07-2011, 10:33 PM
mean green 91's Avatar
mean green 91 mean green 91 is offline
mean green 91 is starting off with a positive reputation.
do a search in this forum and the engine performance forum and you will find TONS of reading material. ignition, exhaust, heads, cam, efi setups, transmissions. on and on
you will have more options for heads with a carb setup. youre obviously not restricted by emissions issues so long tubes and a free flow exhaust are no sweat.
personally, i love the efi even with the speed density setup. with a maf setup from a later truck or a mustang you can do whatever you want for horsepower and not have any fueling issues. my $.02? stick with the efi and enjoy the reliability (assuming proper maintenance)
if you dont mind some fab work and tweeking, the zf transmission is the s$%t. itll be some work to switch but its a great transmission. the overdrive is great to have. a c-6 is a solid auto but i did read somewhere (fte probably) that it uses like 67 hp. and, of course, no overdrive.
have fun dude. put up some pics!
Moving on... 77beater150 Washington Chapter 6 02-17-2015 03:36 AM
1977 Restoration Dads 77 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-25-2014 09:22 PM
Hi! Brake lights, turn signals and reverse lights are not working. AGAIN! 1985 4spd Justin Doe 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 10-03-2013 01:44 AM
Oil smells like gas JustBlaze 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-19-2011 11:33 AM
1973 project mornin-it-up 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-24-2009 12:39 PM
Tags
351w, 400, efi, whp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
