92 Ford F150 Won't go forward. - Ford Truck Enthusiasts Forums
Old 05-06-2011, 06:22 PM
Backslash21 Backslash21 is offline
Backslash21 is starting off with a positive reputation.
My truck won't go forward, reverse is fine. the fluid has been between red and brown for some time but recently took on the slightly burnt smell after I topped off my low fluid level with about a half a quart of new fluid. Would putting in the wrong fluid cause this? The tag on my door with tran code E suggests i have the E4Od tran. If i put it on 1 and rev it a bit it will move but not well. ended up driving it home 5 miles in reverse at about 25 mph ( that got me some odd stares ) what are the steps to finding out what the problem is? Drop the pan and check for debris? do a full fluid flush? partial fluid flush? How much fluid does the tran hold? just pump it out of the dipstick and fill back? It has about 180k miles on it but the fluid's been changed about every 50k. assume i have moderate mechanical ability, just never took apart an auto tran. any steps to finding the problem would be helpful. thanks in advance
Old 05-06-2011, 07:34 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Welcome to the site.
Well here is what the book says about that:
Old 07-05-2011, 02:24 AM
OK, the Old transmission had a fried sun gear, whatever that was, along with other items wearing out and it was cheaper to drop another E4oD tranny in. After I installed it it ran fine for a few hundred miles of breaking in the tranny. Fluid levels are fine, Fluid is new, new filter gasket and pan. Everything. 2k miles later, happens again, started to lose forward gears slowly at first, then altogether. Still have reverse. Replaced the Dtr/Tr (neutral switch / Manual Lever Position Sensor, whatever ) to no avail. Reset my comp and everything else is working fine, no codes, no check engine light, nothin. When i put the truck in drive once again it feels like the transmission engages, and there's even a slight jerk, but no forward. Is it time to drive the truck off a cliff?
Sinserely~
Standing behind my truck at the top of a cliff !
4R100 No Forward or Reverse - HELP Mark Kovalsky Alsride 1999 - 2003 7.3L Power Stroke Diesel 29 07-25-2016 10:27 PM
E4OD to ZF 5S-42 swap break down myakkacracka Clutch, Transmission, Differential, Axle & Transfer Case 13 06-16-2016 12:33 PM
Strange transmission issue DZL JIM 6.0L Power Stroke Diesel 23 06-25-2014 11:48 PM
Did Transmission Fluid Flush...Easy tonyford Escape & Escape Hybrid 8 07-30-2006 07:59 PM
Question about changing transmission fluid E4OD JBronco 1978 - 1996 Big Bronco 8 02-08-2005 09:25 PM
Tags
04, 1997, 2002, 450, backwards, drive, expedition, f150, ford, forward, forwards, generation, move, reversebut, truck, wont, wontgo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
