Batteries die in couple of hours - New Alternator
Used the search function but did not help.
2000 F-350 7.3 Diesel
Here are the symptoms:
Using 2 Optima batteries and a refurbished alternator from NAPA
- Batteries die overnight, so I unplug the negative cable each time I park it
- Batteries smoke and looks like acid is boiling.
- Batteries are around 12.5V when the truck is on
Any ideas?
Thank You in advance
Any ideas?
It sounds like you are MASSIVELY overcharging your batteries. Obviously, smoking batteries is a VERY bad thing. You have a couple options; one of them is NOT waiting!
1. Buy another replacement alternator
2. If you have your stocker, get it rebuilt at a local shop
3. Buy a better alternator
For #3, Rick mentioned a Motorcraft (i.e. OEM). I bought a 200A replacement off Ebay from Eagle Auto Electric. If you get an upgraded alternator be sure to get a thick wire (4ga recommended) for the power supply line to your alternator.
