02 7.3 powerstroke wont start when hot!!! help - Ford Truck Enthusiasts Forums
Old 05-06-2011, 02:42 PM
erkeene erkeene is offline
erkeene is starting off with a positive reputation.
I bought the truck about 4 months ago and I absolutely love it but over the last few weeks is has been acting funny at times, it doesn't do it all the time but it has been getting progressively worse, ill drive the truck all day and no problems when I shut it off and go to start it again it just cranks but won't fire,
*Batteries are charged and in good condition, oil is a little dirty but full, I have no codes or check engine light on, and my wait to start light seems to be working fine!
*If i supply a fuel source(starting fluid) the truck will fire but not stay running
*And let it sit for 15 to 45 minutes fires right up like there was never an issue.
*there are no blown fuses
HELP PLEASE thanksł
Old 05-06-2011, 08:43 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old 05-06-2011, 09:11 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE. Please be careful with starting fluid on a diesel motor. When you turn the key on and the glow plugs heat up, it can ignite the fluid and damage the motor.
I'd suggest you change the oil with some properly rated diesel oil and see what difference that makes. The fuel injectors fire off of engine oil and dirty or worn oil can affect how the injectors work (or don't).
Often times what you're describing is an issue with the IPR. You can either try to clean the IPR and change the o-rings or buy a new one. Since that can get expensive as a guess, do you know anyone with a scanner that can possibly monitor live data when this happens?
Next time you get a no start, try unplugging the ICP sensor since it will sometimes unstick a stuck IPR. The ICP is on the front inboard side of the driver head.
Old 05-07-2011, 09:23 AM
Sweet man thanks for the advice I won't be able to work on it til Monday but i will definitely champ oil and see where that gets me first it is just about do for am oil change anyway, and if that doesn't help or fix my problem ill try the second option, thanks for advice ill post up my progress
Old 05-21-2011, 06:07 AM
Update on my issue!!!!! The day before I was able to service my truck it ****ed up on me so I side what F350-6 said and that was unplugging the ICP sensor to try and stick the IPR, I did this and the truck started fine the next day I changed the oil, filter, fuel filter, and **** and since the truck has been starting fine!! what the ****
Old 02-01-2016, 05:21 PM
robkid robkid is offline
robkid is starting off with a positive reputation.
Thanks 350-6, I'm having the same issue.
Old 02-01-2016, 05:25 PM
Walleye Hunter Walleye Hunter is online now
Walleye Hunter has a very good reputation on FTE.Walleye Hunter has a very good reputation on FTE.Walleye Hunter has a very good reputation on FTE.
Welcome to FTE. You did good by searching the problem to see if you could find your answer. It would be best if you start your own thread stating your problem though if you don't find the answer. That saves everyone from reading the old one to see what's going on with you.
HELP, broke down across town. Intermittent hard/no start now it won't start Dr. Johnson 1999 - 2003 7.3L Power Stroke Diesel 102 10-13-2016 04:45 PM
1999 Ranger 4.0 Cranks but won't Start Fred Furrer Ranger & B-Series 30 09-08-2015 10:08 PM
1991 straight 6 no start fabion Ford Inline Six, 200, 250, 4.9L / 300 3 04-10-2015 08:30 PM
Ignition Timing Issues? 76f350spercamprspeal 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-07-2012 10:41 AM
Cranking issue. Fordownsall Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 02-07-2011 06:39 PM
Tags
1999, 2006, 73, diesel, duty, f550, ford, hot, powerstoke, powerstroke, restart, start, super, warm, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
