Reverse wire location - Ford Truck Enthusiasts Forums
Old 05-06-2011, 01:40 PM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
I'm getting ready to put in my new double din and it said to hook the wire for the camera up to the reverse light wire.
Anyone know which one this is on the harness coming out of the column?
Thanks
Old 05-06-2011, 01:44 PM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
No help but the one that says ebrake just ground out
Old 05-06-2011, 01:48 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Looks to be a black wire with a pink tracer, but it's not on the column.
Here's a wiring diagram for the 2002:
http://www.e-toolbox.com/ads/wiring/va153488.pdf
Pop
Old 05-06-2011, 01:58 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
What Pop Says, Range selector is in Trans
Old 05-06-2011, 02:31 PM
All Around Good Guy
Thanks guys!
Old 05-07-2011, 02:08 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
I'm about to do the same thing. Can someone clarify for me where the wire is?
Old 05-07-2011, 10:44 AM
rat49f6's Avatar
i want to clarify my earlier post
when you hook the wire specified as ebrake to a ground it will allow you to watch dvd's in motion
Old 05-10-2011, 01:32 PM
A/Ox4's Avatar
9 ECHO 1
Ya, I'm going to do the "Parking" wire to a positive so I can do stuff while in drive, but I'm going to have a back up camera. Where is the black/pink wire under the dash? If at all.
Old 09-07-2012, 12:20 AM
djed djed is offline
djed has a very good reputation on FTE.djed has a very good reputation on FTE.djed has a very good reputation on FTE.djed has a very good reputation on FTE.
Trey,
Did you ever find the mysterious black/pink wire under the dash?
I too am seeking the location of this wire inside the cab.
Unfortunately, I don't believe I can defeat my reverse sensor as the radio I purchased shuts off the bluetooth phone feature when the backup camera is active.
Old 09-07-2012, 12:22 AM
A/Ox4's Avatar
9 ECHO 1
Quote:
Originally Posted by djed View Post
Trey,
If memory serves is a black/pink wire coming out of the column. Let me go look.
Old 09-07-2012, 12:34 AM
A/Ox4's Avatar
9 ECHO 1
Yep there it is.. Goodness. Some of my early wiring was terrible. Maybe I will fix it.
Old 09-07-2012, 02:53 AM
Thanks for the pictures.
I spent a few minutes under the steering column and found a group of wires coming out of the wheel shroud that included a black wire with a pink stripe. The wires terminate into a brown plug.
I've attached two pictures - one for perspective and one closer up.
Assuming I found the correct wire, I hope this helps others.
I'll confirm that I located the correct black/pink wire when the camera arrives and I start my install.
Old 04-26-2014, 03:17 PM
rocknrod rocknrod is offline
rocknrod is starting off with a positive reputation.
So did djed ever confirm this wire worked for his reverse camera?
I'm installing one this weekend.
Old 04-26-2014, 04:08 PM
A/Ox4's Avatar
9 ECHO 1
The black/pink is the wire. But I'll let him know to follow up.
Old 04-26-2014, 04:37 PM
kefrko's Avatar
kefrko kefrko is offline
kefrko is starting off with a positive reputation.
So did djed ever confirm this wire worked for his reverse camera? I'm installing one this weekend.
I took power for the reverse lights and ground off of the 7 pin trailer harness back by the bumper. Then I ran the positive wire up along the frame rail with my A/V cable in a wire loom to signal the radio when the truck was in reverse. Little extra wire but I was running the A/V wire anyway and I didn't have to worry about tapping in under the dash. I made the camera only powered when the truck was in reverse. I know some guys might like it hot all the time or on a switch to be able to power it so they can see behind them while they are driving with trailers and such.
Reverse lights wired to upfitter switch Trath67 2017 Super Duty 12 11-10-2016 09:47 AM
auxiliary reverse light wiring 77f2504by4 1999 to 2016 Super Duty 1 10-23-2015 10:35 PM
Where to acquire +12v source that turns on with reverse lights? corksil 1999 - 2003 7.3L Power Stroke Diesel 9 09-28-2015 02:54 PM
Reverse Camera Wiring for F350 XLT Ian Allton Electrical Systems/Wiring 5 08-14-2015 02:17 PM
Reverse Light Wire at steering wheel - 2011 F250 6.7 Diesel JRD761 Electrical Systems/Wiring 3 05-11-2015 03:11 PM
Tags
2000, 2003, 2004, 2009, 99, colum, column, dash, f150, f250, ford, location, reverse, steering, superduty, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
