Reverse wire location
Just had my local audio guy do mine, Pioneer AVIC 960 DAB, back up camera function is pretty cool, you can adjust the parking lines to suit the camera placement & the size of the vehicle. Also has pause & rewind on DAB radio, don't know if you have that over there as you have Sirius & we don't.
I got the Metra Installation kit makes it a neat install.
Received 3,099 Likes
on
on
well on my 02 the black with pink trace is a ground .
i ended up using the black/light green in the loom behind the drivers kick panel that goes to the back of the truck.
everything works as it should now except for the camera. i have to do some diagnosing to see if it is a bad power connection at the rear light, or a bad camera.
on
no idea. all i know is the black/pink wire coming out of the shifter as shown in the pic in the other thread is a ground, not a hot wire.
i ended up grabbing power from the brown/orange wire in the loom going to the back of the truck under the driver side kick panel.
Thank you for the additional followup.
However, our 7.3 trucks were not available with the upfitter switches, those came a couple model years newer, so we wouldn't want someone looking around for that wire based on your post.
Again, thanks, and it might be better posted in the Six-Oh! forum.
Pop
Pop
easy reverse wire
I have an 03 F250 6.0 and the black wire w/pink tracer shown in the photo is ground on mine as well. I used the black wire w/pink tracer that is under the driver side plastic sill cover to the outside of the driver's seat. The plastic cover is very simple to take off, in fact you don't have to completely remove it as it's flexible enough to just pop it up by pulling up with your fingers in the middle where you need access. If you tap into the black/pink wire that is in the bundle that comes from under the driver's seat, that is the back up light wire that you need for the back up camera. it's also very easy to run your wire under the sill and behind the kick-panel. I crossed it over to the carpet side and then just tucked the wire behind the kick-panel and worked the wire up near the firewall behind the e-brake bracket. I also wanted the ability to turn on the camera to check on my trailer/load when driving down the road so I installed an on-on toggle switch that allows you to switch between the normal mode (having the camera activate upon shifting into reverse) and instant on where the camera activates when you switch the toggle.
#28
Old topic, but I'm pulling my hair out on this one. Numerous sources say this is the correct wire to enable the radio head to switch to the backup camera (which is being powered off the rear trailer plug output.) However, in my '01 Excursion this wire is solid to ground, and does not change state when I switch the column to reverse. Reverse lights are working correctly.
Can someone verify this is the correct wire for the '01 Excursion, and can you explain what this wire is supposed to do? It's a diesel, if that makes any difference.
Signed, Confused in CT...
Edit: just caught the posts above, I'll check for the wires in the kick panel. But if anyone has a certain answer on this, I'd appreciate it, I'm outside working on it as I type...Thanks!
#29
#30
