You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am looking at purchasing another truck and have some concerns, its a 1997 with a 7.3, it has 362,xxx, the truck was last licensed in 06, an has only been driven around the yard, but not very often. the truck starts, but not as easily as my 97, and when its idiling, it has a light constant blue haze from the exhaust, and when i pulled the dipstick up, it had smoke coming from there, and the oil cap, and also looked like some from around the CCV. Any ideas how bad this stuff is? The oil did smell pretty bad.
__________________
1997 F250 Ex Cab Long bed, 4x4, ZF5 where the E40D was, 4.10's, being parted out
1994.5 F350 CC LB 4x4, 7.3psd, 5spd, TW chip, 6637 From Clay at Riffraff, 37" GoodYear Military OZ 4.10's,gauges 3"dp, 4" undercab, dual 5" stacks
1995 F250 EX Cab LB 4x4, 460, e40d, 4.10s being parted out
You could take the oil cap off and put it upside Down over the fill hole and see if it blows off or rattles off both my trucks it just rattles off my old 97 had some much you could see if coming out from under the hood and it burnt your eyes and always idled with a haze and smelled bad! How much are they asking for the truck?
The cap didnt seem to blow off, the truck has been sitting for along time and has 06 fuel in it. it seems to idle and rev smooth.
Its a 1997 Crew cab 4x4 with an auto and they where asking $2000, he dropped down to $1750 while i was there, its about 6 different colors, and still needs alot of work, interior is completly gutted, he says he has all the parts, has 4.10, and comes with an extra rear, just needs alot of little work, and i mean alot, i cant test drive it either becuase it has now brakes, one of the rear brake lines is leaking,
__________________
DANGER Will Robinson!!! I bought a truck similar to this story. It had been sitting a while , with occasional starting for two -three years because of burned UVCW when I fixed it and started driving it. The thing was smoking lightly, then went heavy and pumping oil out tail pipe. The turbo went, one vendor told me because of sitting, the oil drains away from turbo. I started running it and there she went.
__________________
'96 250 4x4 5 spd,Ext.cab, several mods
'95 350 2X4 5 spd, similar to above mods
'90-250 4x4 w/'93 7.3 IDI straight pipe K&N,
'89-250 4x4 7.3 IDI straight pipe K&N,300k+
'87-250 4x4 6.9 IDI w/Banks Turbo,GW 4 speed
'83F-350 2x4 6.9 IDI K&N, with 125k on 2/26/11
