Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
- Tire Modifications and Size Calculator
Overview of popular modifications to customize your truck
2010 E350 wheels/tires/suspension mods
Another pic of the bags. I really like this kit. It fits nice around the frame. It gets a bolt up through the bottom in the existing jounce bumper bolt hole, and then a bolt on the outside of the frame. I just had to drill one hole for each bracket. The frame doesn't appear to be made of hardened steel, like some frames are. It was pretty easy to drill out the holes. Just watch for the AC and brake lines on the drivers side. It really helps to have a 2nd person to help with this job.
Air Lift Air Bag Suspension Kit
Part # 57138
Vehicle 2010 Ford Econoline
Submodel E-350, 2WD
Part # 57138
Submodel E-350, 2WD
I like the tires pretty good so far. They are more aggressive looking than I thought they'd be. They are just a bit louder than my previous wimpy skinny OEM 225 wide tires. The ride feels pretty good. BFG Rugged Terrain 275/65/18 Load Range E.
http://www.tirereview.com/article/84...rain_tire.aspx
This is the closest that the tires get to the fender.
Yes, you mentioned that in post #23. They still use a TTB which connects to the XYZ PDQ which applies pressure to the BIG OL TITAYS, which then makes the muffler bearings engage the clutch oil and makes the van run smooth.
