2010 E350 wheels/tires/suspension mods - Page 5 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-27-2014, 06:44 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
  #61
Old 01-29-2012, 07:37 PM
RocketmAAn's Avatar
RocketmAAn RocketmAAn is offline
RocketmAAn is starting off with a positive reputation.
revelation
Quote:
Originally Posted by Killer RC View Post
I got the backup lights installed, and added some pieces of no-slip tape stuff.
This bumper is extra beefy. It weighs about 150 pounds. The hitch has a 20,000 pound tow rating. No drilling was required. Ten bolts hold it in place. It mounts to the stock bumper mounts, and also to both chassis rails. The hardest part was getting the backup sensors installed and lined up. It's best to install the sensors, get the bumper mounted, and then plug in the harness to the 4 sensors.
Awesome. Is it just luck that the color looks like it matches the body or can you order it to match? If I hadn't seen this, I would have gone for a chrome bumper. I like this much better. If ya had the dough, makes ya wanna go and get a matching front bumper and maybe grill, eh?
  #62
Old 01-29-2012, 09:08 PM
RocketmAAn's Avatar
Yet another question.
I'm sorry, but there doesn't seem to be any posts less than 7 years old to answer my questions about this mod.
How are most of you protecting the areas behind the wheels from taking a beating? Spraying on some extra undercoating? Stainless metal shield? Hard clear coat on painted lower?
I made a mistake not installing mud flaps on my 99 E350 XLT Club Wagon (converted for cargo). It would have kept the side much cleaner (always tar from somewhere). It may have prevented the large square hole that developed behind the right rear well. The first time I was "cash challenged" and patched it with some heavy galvanized, some silicone and stainless screws. After adding 246K to the 77K it had when I bought it, the hole is back. ((Fun side assunote: Although I couldn't confirm through title records, I suspect the van was originally used for a prisoner transport judging from the plethora of mounting holes left in the interior and the GPS or roof strobe wiring to the roof. Oddly enough, I sold the seats to a prison in downtown Chicago))
Since the van is white, I didn't think black mudflaps would look good. At one point I got a hold of a plain white semi-truck mud flap at a truck stop to fabricate my own. Looking back, I think I'd go with some black ones made frbom a large truck flap so I can make it the shape I want for both looks and to protect higher up in the well. If you don't like the black with a lighter colored van, I wonder if you can use a flex type bumper mix of paint to color-match the rear exposed surface of the flap? Found one reference in the forum which looked interesting. It was a "Ford Splash Sheild Assembly" for an F-Pickup. It had some extra protection around the rim for wide tires. Don't know if it can be used in a van.
Several mentions about the axle spacing. The front and rear tracks are different. The track for a non-dually E350 is about 69.4 inches in front and seemed to vary up AND down from 1998 thru 2011 between 66.4 to 67 inches (I only looked at 5 years). I think the my manual says max dog track (front-back diff) is 1.25"? I do remember an interesting comment in the diagnosis section that it was common for people to think it was out of alignment when looking at it from behind because of the track diff. I can only think that it is that way to accomodate the dually on some models? Should make the spacer mandatory on the 15 passenger models.
happy trucking
  #63
Old 01-30-2012, 07:45 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Good question RocketmAAn----any signfigance to the capitalized double A's ??
Mud flaps mounted behind the wheels are great ideas and while sometimes unsightly great reduce incidents of eventual rust. As you point out those areas constantly pelted by road debris in any climate removes much of the factory finish and rust inhibiting primers/coating.
Today there are urethane sheet masks either ready made or can be custom cut by sign or vehicle graphics outfits. If that's too expensive you can probably find the material yourself and a little DIY gives you almost invisible wheel well protection.
Another thing to always keep in mind if you live in winter climates is cleaning the wheel wells regularly. Caked mud holds moisture against the body which c can promote rust in time.
Just a bit of information-----hope its even partially helpful!
  #64
Old 01-30-2012, 07:45 PM
E350John's Avatar
E350John E350John is offline
Enlightened User
E350John is starting off with a positive reputation.
I went with the Bushwacker "Extend-A-Fender" flares on my E350. They keep the major crud off the body, though mud flaps would add a bit more protection at the bottom. I'm running the 2" rear wheel spacers and LT265/70R17's. Here's a photo of the front and rear.
  #65
Old 02-01-2012, 04:55 AM
JWA's Avatar
JWA JWA is offline
John do your tires extend past the outside of the body at all?
Those flares not only look decent but have to give a lot of protection too.
  #66
Old 02-01-2012, 02:02 PM
E350John's Avatar
Enlightened User
JWA,
Yes. When I went to the aftermarket wheels and larger tires, they were beyond the body a bit. I was getting a lot of road spray the entire length of the van. The flares made a huge difference, extending just beyond the tires. I like the way they look with all the other black accents.
  #67
Old 02-01-2012, 08:00 PM
E350John's Avatar
Enlightened User
Quote:
Originally Posted by RocketmAAn View Post
What is the limit for lifting before you have to make other mods?
Do you need to make a camber adjustment when lifting the front?
Is there a kit or an unlock code to recalibrate the speedometer?
With large tires, do you need to change the automatic's shift points to stay in the power band (or just change the rear-end) or does the computer do a good job of sensing load and not just shift using rpm?
Don't know what my next van will be, but if I want a diesel, I'd like to see the coming? full size transit. Maybe if the demand for Duramax in the pickups drops to the point where they're motivated to come up with some kind of innovative coolong solution, we'll see it back in the E-Vans.
I think some nice front fairing, fender and duel hood scoops would do the job LOL Varooom
Happy Truckin
RocketmAAn,
I'll attempt to answer your questions.
Not sure I want to guess at a limit, but I would think that any lift requires correction in the front alignment and the driveline angle. I would expect to use a degree corrected lift block at the leaf springs with any rear lift.
I did make a camber adjustment when lifting the front. I found some two-piece, 4-degree camber bushings. I probably ony needed 2-1/2 degrees with the 2" lift.
I was able to correct my speedo and rear diff ratio with an SCT Tunner in the custom options section.
I had allready changed my rear diff ratio to compensate for tire size, and the shift points were improved with the performance tune in the SCT Tunner. My differential guy said that going from 3.73 to 4.10 would compensate for 3" of tire height increase.
Hope this helps.....
  #68
Old 02-05-2012, 12:25 AM
RocketmAAn's Avatar
Thanks for all the information. Had no idea there was something like a "degree corrected lift block". I at least know enough, to know I don't know enough, now!
E350John, those are bad *** wheels. gotta think about going bigger than stock. Thanks for all the info.
JWA: I take it the urethane sheet masks can be applied on the rocker panel as well as the well and underneath. A vehicle graphics place would probably supply stuff that won't yellow under UV exposure. Thanks
RocketMan was a nickname given to me by an expeditor/courier dispatcher I once drove for (later they tried to elevate that to "Sputnik", but it didn't stick). Think I was in a Cutlass Ciera Wagon (one of the few cars that fit) or as my neighbor called it, "a chick magnet" ;-). When I started playing poker I used the name with the AA to rep a starting Holdem hand of a pair of Aces, aka: Bullets, American Airlines or Pocket Rockets.
  #69
Old 02-05-2012, 06:43 AM
JWA's Avatar
JWA JWA is offline
Rocket you're 100% correct about the urethane over lays----today they're formulated for vehicles which would include weather resistant with the ability to withstand wheel well or rocker panel use. The only consideration if self-applying would be where or how the underside edges end. I'm sure any shop you contact will have full information on this.
Not being a poker player---can't afford that luxury---I'd never have thought it was a hand although the American Airlines thought did enter my mind. Thanks for sharing!
  #70
Old 05-27-2012, 10:26 PM
njvig njvig is offline
njvig is starting off with a positive reputation.
Wheels
Killer RC where were you purchasing those wheels from? Those look pretty close to the stock Ford premium wheels. How big can you go without doing the body lift. We have a 12 passenger E-350 too and would like to soften the ride. I was hoping to find some softer tires when I change the wheels. We have four kids and don't need that heavy duty truck ride. Hopefully we can accomplish this without jeopardizing the safety of the van.
  #71
Old 08-08-2012, 10:19 AM
Matzu Matzu is offline
Matzu is starting off with a positive reputation.
Where can you find the lift kit with the RCS Upgrades? I have a 2009 Ford E350 with RCS (2wd) and would like to lift it between (2" and 3").
  #72
Old 08-08-2012, 10:46 AM
SilverE350's Avatar
SilverE350 SilverE350 is offline
SilverE350 is starting off with a positive reputation.
Quote:
Those spring spacers came from Maxx Lift Suspension.
But- you will need to source some hardware yourself. Plus shocks.
Action Vans makes a 2" lift using taller springs, for RSC vans. They don't list it on their website, but I've spoken with a guy named Larry over there and he told me about it. $800 comes with 4 shocks and all hardware.
1-949-361-6508.
They probably have a toll free # but I don't know it.
  #73
Old 08-11-2012, 10:24 AM
tomasz646 tomasz646 is offline
tomasz646 is starting off with a positive reputation.
what brand and part or model # is that air kit ? im looking to get one for my 2005 e-150 and what compressor did you use with ?
first ae usage jps47 1999 - 2003 7.3L Power Stroke Diesel 2 11-10-2013 05:16 PM
Removable winch henritrinelli 1978 - 1996 Big Bronco 26 07-24-2013 05:03 AM
No issue here, just wanted to show what my wife did :-( tinyguy82 Explorer, Sport Trac, Mountaineer & Aviator 6 04-22-2012 11:38 AM
F-100 6 cyl. Idle Adjustment Screw? dancraig 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 08-14-2011 10:00 PM
I had to do it! thejean Alberta Chapter 5 07-17-2011 01:42 AM
Tags
2010, 350, e350, eclass, ford, mods, race, removed, rims, seats, suspension, suspention, truck, upgrade, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
