Off Road Lights (Post Pics!) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-06-2011, 01:38 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
I wanna add some off road lights to my truck. But I cant decide how to mount them. What are your opinions/ideas? Post pics of your off road lights.
Old 05-06-2011, 01:24 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
I ran 4 KC 800 series lights (2 fog/2 beam) on a Randy Ellis bar on my 2000 F250. Loved the combo, lots of light. Didn't have much use for it once I moved to PA (from AZ), but they worked great out in the dunes in Cali...
Last edited by 2000silverbullet; 05-06-2011 at 01:26 PM. Reason: added another pic
Old 05-06-2011, 01:49 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Mine are probably smaller than what you are talking about, but I use them off-road.
Old 05-06-2011, 03:06 PM
2011SD's Avatar
2011SD 2011SD is offline
2011SD is starting off with a positive reputation.
I have 2 Hella 500 FFs mounted in my bumper they work great and are pretty cheap too
Old 05-06-2011, 04:42 PM
Quote:
Did you utilize an upfitter switch for those or are they relay'ed off the fogs? Looks good. I'd like to get something "stealth" in my '11 for the backroads of PA.
Old 05-06-2011, 04:45 PM
2011SD's Avatar
Quote:
I used one of my upfitters
Old 05-06-2011, 05:25 PM
barthel's Avatar
barthel barthel is offline
barthel has a good reputation on FTE.barthel has a good reputation on FTE.
I only have 2, but they're PIAA Crystal Ion Fogs. I LOVE these things in the desert.
Old 05-06-2011, 09:46 PM
wideglidewoody00 wideglidewoody00 is offline
wideglidewoody00 is starting off with a positive reputation.
barthel did you mount the stud down thru the plastic valance or up thru the top then spin the guards around. Do they bounce around or did you reinforce the plastic with a brace? Just curious.
Old 05-07-2011, 12:42 AM
jlmotox's Avatar
jlmotox jlmotox is offline
jlmotox is gaining momentum as a positive member of FTE.jlmotox is gaining momentum as a positive member of FTE.
4 - 8" procomp lights on a custom made light bar.
Old 05-07-2011, 12:43 AM
A/Ox4's Avatar
9 ECHO 1
Quote:
What kind of winch setup you got there? is that the hide away kit?
Old 05-07-2011, 12:48 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
I will take more tomorrow.
Old 05-07-2011, 12:51 AM
A/Ox4's Avatar
9 ECHO 1
Quote:
Please do. I think I'm going to go with a brush guard.
Old 05-07-2011, 01:15 AM
barthel's Avatar
Quote:
They're actually mounted to the bumper, there's steel behind the plastic right there. i used a step-drill bit to make the hole.
Since they're essentially mounted upside down, you have to take the lenses off and turn them around, then put the guards on the right way. Only problem is, the vent/drain hole is at the top.
Old 05-07-2011, 02:32 AM
jlmotox's Avatar
Quote:
it's a Warn 12000 winch with the Warn "hide a winch kit"
Old 05-07-2011, 06:15 AM
high ho silver's Avatar
high ho silver high ho silver is offline
high ho silver is gaining momentum as a positive member of FTE.
Let's see those aftermarket exterior lighting set-ups!! RUNVS 1999 to 2016 Super Duty 227 01-11-2017 11:31 PM
1997 f250 heavy duty aftermarket headlights Grizzlyraptor 1987 - 1996 F150 & Larger F-Series Trucks 10 06-03-2013 09:28 PM
Light Bars? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-16-2011 11:58 PM
Extra Lighting. Need To See Some Pics! cdrmotorsports 1999 to 2016 Super Duty 31 06-09-2009 08:30 PM
off road light options 93FordCTD 1999 to 2016 Super Duty 5 12-26-2008 04:37 AM
Tags
2011, 64, brush, f150, f350, ford, guard, hunter, images, lightforce, lights, offroad, pics, road, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
