1999 F250! Need help!
alright guys, i am new on here and thought I would give it a shot since i love my truck, and to share with others. Anyway I got this problem with my speakers, none of them are working except for the passenger speaker. I have put a new speaker in the driver door to see if that was the problem and it didnt work. i was just wodnering if anyone could help out a little bit, i dont really know where to start lols!
Also i was looking for some suggestions about some good mods/ accessories without spending a lot of money!!
Thanks guy, help me out here! lol
i always test my speakers with a 9v battery. i used to do it when i installed home theater speakers too. just take (-) and (+) and touch to either side of the batter poles. use a jumper to get the connection from the wiring harness if you take out the radio. that way you can tell if itsyour wires somewhere in the truck or your headunit
yeah i was thinking about it being the head unit but i dont see how that could really be the problem if the other speaker is working, but i am going to take the door panel off and get the wiring harness and see what the deal is. how much of a pain is it to get the harness out from the door and in the cab to work on it or rewire truck? anyone done it?
I'd find someone with a ford stereo and pull yours out and try the other one and see if it works.Then you would know if its the head unit or the wiring.It only takes a minute to pull it out if you have the release tool [$5 at Walmart].
Last edited by mnpowerstroke99duty; 05-04-2011 at 09:53 PM. Reason: Tired and didn't make sense!
it IS the head unit....get an after market radio and install it and i bet you your problems will be solved....as for the big hole..either get a DIN radio with a dash kit..perfect for my phone and radio remote....or get a double din and trim the dash a little...i currently have the din with the kit and a 7 in LCD monitor that slides out.
http://www.amazon.com/BV9990-Dash-Wi.../dp/B001QXDSR2
sorry for my english
get a votimeter and check for continuity in the speaker wiring cables, the are two version of wiring cables on the literature but if you give me your VIN i can tell exactly what color are the wires for your speaker.
the other way its like a destructive test but working.. :P
Near the stereo harness, connect the driver speaker with the wires of the passenger speaker (that you know its in working condition) and see what happens or connect the driver speaker instead of passenger speaker. Be careful when you remove the door mounts.
lilsmokey
03-27-2012 09:54 PM
86460boy
03-16-2012 05:01 PM
FarmingFord
06-14-2010 09:09 PM
