Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 05-05-2011, 06:20 PM
Marky48170's Avatar
Marky48170 Marky48170 is offline
65 f250, 67 f100, 76 f250
Garage is empty, add now
Marky48170 is starting off with a positive reputation.
Rear leaf spring bushings
I have a 1988 2 wd ranger that needs the rear spring bushings replaced. Just wondering if anyone can give me some tips on replacing them. Also just go with stock or urethane?
  #2 (permalink)
Old 05-06-2011, 09:14 PM
Phinxter's Avatar
Phinxter Phinxter is offline
1992 Ford Ranger
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
going to replace my rear shackles and hangers tomorrow. I have a full arsenal of tools, I'll let you know what works. The shackle kits I have came with rubber press in bushings.
__________________
Phinxter "Have you ever worked on a Caddy?"
1992 Ford Ranger Danger 3.0 5spd 4X2
1993 Plymouth Sundance (Member of the Allpar 200k club)
2009 Saturn Aura
2004 Jeep Grand Cherokee Limited V8
  #3 (permalink)
Old 05-07-2011, 07:55 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
I haven't done the Ranger, but did a Comet when the leaves needed to be re-arced. Lots of grunt work. The bushings don't want to come out and the new ones don't want to go in without a lot of persuading. The shackles don't want to let the bushings come free even after you pull the long bolts & nuts. Just heavy duty grunt work. Removing the U-bolts is not an easy task either. From memory, to have someone do all the removing and installing would have been a small charge on top of the re-arcing. If I ever do it again, I plan on letting the spring shop do the work, as they have all the tools AND have done the task eleventy-seven times, so know all the tricks and have all the 6 foot long prybars you need to muscle the stuff around. Have fun.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #4 (permalink)
Old 05-07-2011, 12:55 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
easiest way is to burn the old bushings out and then put urethane ones back in ! you can also drill small holes around the bushing to help them come out ! there should be a metal sleeve on the outside of the old bushing , you can take a torch and trim it out or a chisel and cut it out or a sawzall and cut one side then it would come out ! if you use a chisel the the spring must be put on some thing solid so you can hammer with out any rebounding of the spring !
  #5 (permalink)
Old 05-07-2011, 08:29 PM
Phinxter's Avatar
1992 Ford Ranger
welp got the old mounts out, or should I say rivets with a bit of metal attached using a cutting torch followed by an air hammer. The bushings came out pretty easy after I cooked it a bit. Just need to press in the new ones.
__________________
2009 Saturn Aura
  #6 (permalink)
racsan's Avatar
racsan racsan is offline
1993 Ford Ranger
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
i use a torch to make things easier, dont count on using any old hardware. clean things up real good and use anti-seize on the inside of the spring eye (as a lubricant) when you go to put the new bushings in. to do that i used a long bolt with some washers and a socket to "press" the bushing back into place. not a quick,clean or simple job, but it is at-home do-able with the right stuff. or take the springs off and take them somewhere and have it done.
__________________
'93 Ranger Supercab,4.0L,4x4 5spd-hurst equipped. mile marker manual hubs. "the green machine" http://www.myspace.com/small_dog_trucking
http://www.cardomain.com/ride/3216869
  #7 (permalink)
Old 05-07-2011, 09:10 PM
Phinxter's Avatar
1992 Ford Ranger
I thought of this before I saw this video
YouTube - here is a simple way to replace those worn out leaf spring bushings
__________________
2009 Saturn Aura
  #8 (permalink)
Old 05-07-2011, 09:16 PM
5.0 Heaven's Avatar
5.0 Heaven 5.0 Heaven is offline
1996 Ford Explorer
My Garage
5.0 Heaven is starting off with a positive reputation.
Just a small tip on this topic. I use my torches on all kinds of jobs to get "frozen" items to come loose but you need to be real careful using high heat on spring steel. It does not take a lot to change the metal in ways you will not be happy with. Cutting one edge with sawsall as and driving out with air chisel as mentioned is safest bet.
  #9 (permalink)
Old 05-07-2011, 09:20 PM
Phinxter's Avatar
1992 Ford Ranger
Quote:
I used a propane torch, I found that if I just caught the bushing on fire that was good enough. I didn't really want to apply any more heat than necessary.
__________________
2009 Saturn Aura
  #10 (permalink)
Old 05-08-2011, 05:00 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
TO REMOVE THE BUSHING TAKE A 1/4 DRILL BIT AND DRILL A LOT OF HOLES THROUGH THE RUBBER PART OF THE BUSING. THE BUSHING THEN SEPARATES AND THEN METAL PARTS COME OUT.......IT TAKES ME ABOUT 2 MINUTES TO REMOVE A BUSHING AND I DON'T HAVE TO WORRY ABOUT THE TORCH DOING ANY DAMAGE.
__________________
1999 Reg Cab, Styleside, 2.5L, 2WD, M5OD, RABS, no A/C, MFG. Date 12/98, Gatorback belt, Autolite DP plugs/wires, Fluids and Maintenance done regularly, 141k as of 5/2/2012
Unless you have gone to the control panel and created a detailed signature of your truck similar to mine you are not doing all you can to solve YOUR PROBLEM!
  #11 (permalink)
Old 05-08-2011, 07:18 PM
Phinxter's Avatar
1992 Ford Ranger
I used the same method as the guy in the vid. worked good and the tool cost about $6 to make. The rear end went up like 3 inches. I think if I ever had to do the front mounts i would rather use to poly style bushings though.
__________________
2009 Saturn Aura
Tags
1997, 93, bushing, bushings, explorer, f350, ford, installing, leaf, ranger, rear, remove, replacing, spring, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
