88 F250 exhaust - Ford Truck Enthusiasts Forums
88 F250 exhaust
Old 05-05-2011, 10:44 AM
JAndrews392 JAndrews392 is offline
JAndrews392 is starting off with a positive reputation.
88 F250 exhaust
I have an 88 f250 351 Windsor, currently have cat to a glass pak single pipe, sounds really bad and hanging down just looks like crap. I want it to sound good but don't have a ton of money to spend. Any recommendations?
Old 05-05-2011, 10:54 AM
otlw 96 otlw 96 is offline
otlw 96 is starting off with a positive reputation.
i have a 96 f250 351w with pacesetter headers and 2.5 in true duals and it sounds amazing!!!
Old 05-05-2011, 11:55 AM
I would do anything to put headers on, but in college and just dont have the money
Old 05-05-2011, 05:40 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
I feel your pain.
On my 83 302, several years ago, I put a Walker Hemi Turbo muffler 2.5" SISO and had it exit before the rear passenger wheel. It sounded great. I have used the same muffler on a single exhaust on a couple of GM and Ford V8s and they all sounded good and the muffler was cheap. On my 350 sbc Suburban I did use the 3" model and had it exit all the way back.
Fortunately the Windsor sounds good with almost any low flow muffler. Check youtube for sound clips.
regards
rikard
Old 05-06-2011, 04:15 PM
'89F2urd's Avatar
'89F2urd '89F2urd is offline
'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.
you can put long tubes on your truck for about 200 bucks if that means anything for ya.
Old 05-07-2011, 07:52 PM
thanks for the help guys
Old 05-07-2011, 08:32 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
Cut out the cat and use a cherry bomb extreme muffler with a DISO (2.5I to 3" out) with a 3" tailpipe
I want more Turbo Singing Sound RDC F250 7.3 6.0L Power Stroke Diesel 6 10-10-2009 10:40 PM
cold start 88 f250 rostena 1987 - 1996 F150 & Larger F-Series Trucks 1 02-28-2008 01:51 PM
88 clip to 84 ? royzell 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 02-21-2008 03:01 PM
Back pressure sounds OldSHO 6.0L Power Stroke Diesel 4 05-14-2007 07:33 PM
Remove Muffler?? fordpower88 1999 - 2003 7.3L Power Stroke Diesel 5 07-18-2006 06:20 PM
Tags
1987, 351, 88, 89, 95, cat, diesel, exhaust, f150, f250, ford, forum, forums, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
