429 in a 78 F250 - Ford Truck Enthusiasts Forums
429 in a 78 F250
Old 05-05-2011, 02:03 AM
Bledsoe76 Bledsoe76 is offline
Bledsoe76 is starting off with a positive reputation.
429 in a 78 F250
Bought an old farm truck from friend of a friend of a (you get the idea). The truck has an old 429 out of a galaxie 500. I changed the oil and filter and put in 5 quarts. Ran it for a few minutes. Let it sit a while and the dipstick came out with 0 oil. I added a 6th quart and ran it again, let it sit and there is about an 1/8 an inch of oil on the stick. Way under ADD mark. Anyone know the length of a 429 stick from insert to tip? Im guessing this isn't the right stick. Im not very knowledgeable with engines but i know the basics. Any and all assistance would be greatly appreciated.
Old 05-05-2011, 04:29 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Are you sure the engine is from a car? my original '78 F150s 460 took 7 quarts to be on the full line.
Old 05-05-2011, 12:03 PM
shookdaddy shookdaddy is offline
shookdaddy is starting off with a positive reputation.
Yea man u need to find out if someone put a trk oil pan on it they hold a lil more oil than a car pan expectially if it came of a f700
Old 05-05-2011, 09:07 PM
ok. how would i go about finding that out. there should be a PN on the outside of the pan right? Ill check tomorrow. Its pretty dark now. Also where would the engine stamp be? I kinda wanna make sure the engine thats in it is actually a 429 and I would love to know the year of it.
Old 05-05-2011, 09:22 PM
There should b a tag on the driverside valve cover if its not u might want to ask one of the other guys here. I really don't remember where mine are. But if it has a bigger oil pan u will b able to tell it will either b real wide or hang real low under ur trk.
Old 05-05-2011, 11:03 PM
k. ill check tomorrow. Thanks.
Oil refill capacity after change? pwjackson42 1994.5 - 1997 7.3L Power Stroke Diesel 14 01-22-2016 11:08 AM
need help don't know what to do thelawlesslollis 1997 - 2003 F150 5 05-17-2015 11:22 PM
Oil Issues NateMack06 Modular V8 (4.6L, 5.4L) 1 04-23-2015 07:52 AM
360 to a 429 JakeNail 1967 - 1972 F-100 & Larger F-Series Trucks 7 04-15-2015 03:13 PM
429 to c6 xpl 1968blue 1967 - 1972 F-100 & Larger F-Series Trucks 11 12-15-2014 04:56 PM
Tags
1978, 250, 429, 78, engie, engine, f150, f250, find, ford, stamp, swap, truck, trucks, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
