Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign in using an external account
Register Forgot Password?
1978 - 1996 Big Bronco SPONSORED BY:
  #856
Old 03-20-2012, 12:08 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
WAFTE Chapter LDR
GruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant future
pages/Bronco-Nation/333812929968547 GruesomeJeans
Quote:
Originally Posted by ManfredVonRichtofen View Post
GO buy a machete now and mount it on your dash then go to the nearest lake.
I second this.
Also i got new 35" MTR Kevlar tires put on and their horrible in the snow.... 4wd made it worse though and i think the larger area of rubber on the ***** made it easier to slip...
__________________
1978 Ford Bronco Ranger XLT *The Green Machine* 351Mutant§35x12.5R15§3" Body lift§
1987 Ford Mustang GT§Drag Radials§5 speed§FAST!§PGM
Leading The Washington Chapter With An Iron Fist! - Dylan
Visit Washington Chapter HERE!
Washington Member Map
  #857
Old 03-20-2012, 12:13 AM
jthorngate3's Avatar
jthorngate3 jthorngate3 is offline
jthorngate3 is a splendid one to beholdjthorngate3 is a splendid one to beholdjthorngate3 is a splendid one to beholdjthorngate3 is a splendid one to beholdjthorngate3 is a splendid one to beholdjthorngate3 is a splendid one to beholdjthorngate3 is a splendid one to behold
42209261 Fordx4bronc3545
Yeah, those MTR's are definitely not good snow tires. I have heard the Duratrac's though are supposed to be pretty awesome in the snow. Both tires still made in the USA I believe.
__________________
Josiah
2010 FFH(Eve)...slowly accepting, MPG helps
1988 F150 4x4 5.0 AOD(Gert)...Big plans, or not.
Gone but not forgotten: 86 F150 4x4 I6(Clyde)
  #858
Old 03-20-2012, 01:58 AM
Nighteyez's Avatar
Nighteyez Nighteyez is offline
FTE NorCal chapter LDR
Nighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant futureNighteyez has a brilliant future
Wow, $900 for tires, and they suck in the snow. Good thing there is no snow in Washington!
Jim
__________________
90 F350 Centurion, XLT Lariat, CC, dually,460/auto, Sold
Proud to be a veteran
Click Here To Join The Nor-Cal Chapter
  #859
Old 03-20-2012, 05:38 AM
justin Wallace justin Wallace is offline
justin Wallace is starting off with a positive reputation.
Here's my new project. Bad picture quality but I'll have better later.
Just bought it. The front diff needs replacing, the trans leaks like crazy, and the engine is a little tired. This is ok though, I have a parts bronco with everything I need. I also have a 408 ready for a home. I have had it for a couple of weeks and already have the motor out and the new one waiting to go in until I remedy the trans and paint the engine compartment.
This one's a 78 XLT
Click the image to open in full size.
  #860
Old 03-20-2012, 08:04 AM
speedyweasel's Avatar
speedyweasel speedyweasel is offline
speedyweasel is gaining momentum as a positive member of FTE.
Quote:
Good times! Nice choice. I cant see where you're from (using my phone) but I've got three C6s if you need one. At least one is definitely from a Bronco so it has the right tailshaft and housing. And how certain are you about the trans leak? I ask because i was sure, too, until i discovered a badly leaking oil pressure sender last month -- sending oil down the block and bellhousing. Just a thought.
  #861
Old 03-20-2012, 08:15 AM
Quote:
Thanks. I traded my 72 f100 with a blown motor for it. I'm from Amarillo,TX. I have an almost complete 79 for parts. It has a good c6.
The front pump seal has a small leak but there is a big one coming from the linkage where the transmission kickdown is supposed to be. Needless to say, the tran was running like crap. I am gonna put in a new modulator and vacuum line and change the filter and stuff. The intermediate belt was way out of adjustment too.
I should post a build thread maybe. I just dug into it and it should go pretty fast and furious.
  #862
Old 03-20-2012, 08:33 AM
GIGGER's Avatar
GIGGER GIGGER is online now
Canadian Trucker
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Justin, great looking 78 there
__________________
WE MISS YOU PAUL HILL June 6th 1955-May 28th 2014 ....... REST IN PEACE MOM & STEVE (BRICKS) PRICE
Gerry- .... Slackmaster #23, avid snow hater
2006 F350 Lariat
2006 Mustang vert, Windveil Blue,
2010 Forest River Sand Piper 345RET 40ft Fiver
  #863
Old 03-20-2012, 09:32 AM
Quote:
Thanks. The picture there is actually from right before I bought it. Its actually kind of a POS at the moment. There is random holes drilled in stuff. The interior looks like vagrants lived in it. The seats are all kinds of tore up but its a work in progress. It sat for 8 years and I'm bringing her back to life.
It just so happens that all the parts that were taken from it are on my parts bronco in the barn.
  #864
Old 03-20-2012, 12:43 PM
Zip's Avatar
Zip Zip is offline
BC Chapter LDR
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
This one's a 78 XLT
Very nice.
__________________
Chris,#12 BS'er/Official Slackmaster #7/AVIDEST WINTER HATER WITH SLEDS
BC Chapter Member/Leader
JOIN THE BC CHAPTER HERE
Zoodad Mod, Blue Spring, Sinister Coolant Filter, Tripple Gauge Pod, Scangauge II, Leveling Kit, Straight Piped
  #865
Old 03-20-2012, 08:48 PM
WAFTE Chapter LDR
WOO ANOTHER 78 , @Jim, actually it was a great deal for the tires BUT it has been snowing lately. First day of winter and we had snow/rain/sleet mix today. non of it is sticking but it is there. As for Justin you should do a build thread, my 78 is my rolling project. I have to fix it as i drive it and i am slowly fixing things that the PO either broke or didn't fix correctly. Mostly wiring.
__________________
  #866
Old 03-20-2012, 09:01 PM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
LOL @ Grusome....
First thing I always do is pull those stupid crimp on wire taps off and get out the heat shrink and solder iron! 90% of wiring problems I've found were caused by them. Cheap junk!
__________________
Gregory "Greg" Hupp
near Meadow Grove NE.
1991 Silver anniversary Bronco
1978 Custom Bronco
It aint built to go fast! It's built to get there!!
  #867
Old 03-20-2012, 09:06 PM
WAFTE Chapter LDR
Haha i wish it were that easy, most of my problems are cause the dummy PO cut the wires and twisted them back together then taped them. So when they move it loses connection or has a weak one, hence my back window going up slow if at all. I was putting my deck in and saw the wires were all messed up so i went in and butt connected them with new sections of wire and it goes up just fine now. My turn signal lights in the front and my tail lights are the same way, i got pulled over cause on of my tail lights was out due to the bad connection. IIRC my headlight wiring is the same all cut up.
__________________
  #868
Old 03-20-2012, 10:05 PM
Nighteyez's Avatar
Don't you just love wannabe mechanics?
Jim
__________________
  #869
Old 03-20-2012, 10:29 PM
Encho's Avatar
Encho Encho is offline
The Brown Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
I do twist them together but I use heat shrink on them so they end up tight and so far i haven't had any issues (i've only done this to slim wires). I guess solder is a better way to do it, i will consider this next time i repair a wire.
__________________
1993 Special Edition Bronco: 5.0lt V8, E4OD Auto, MM Supreme manual hub lockers and a sweet roof tent, ROTW in 2/9/09
My Write-ups: Ford Steering Box Rebuild / Ford Front End Rebuild and auto hubs replacement / Ford Rear Drum Brakes / Ford E4OD Cooler & Shift Kit mods, drain-refill procedures R.I.P. Steve, you will be deeply missed my friend
  #870
Old 03-20-2012, 11:58 PM
FourXFord2's Avatar
When I bought my '91 the rear didn't work at all, ended up pulling the t-gate harness and replacing some of the wires (kept a working harness from my totaled out '89) Then went through and removed 40 ft of useless wiring, and at least a dozen non functioning crimp on taps.
__________________
Gregory "Greg" Hupp
1978 Custom Bronco
Similar Threads
Post pictures of your F150 Trail Rig or Rock Crawler here! derherr65 Offroad & 4x4 52 02-06-2013 11:42 PM
Members Rides - Tell us about your Bronco fordborn 1966 - 1977 Early Broncos 53 09-26-2006 07:51 PM
calendar girls Fordlover55 1966 - 1977 Early Broncos 9 11-26-2004 01:23 AM
92 - 96 Bronco/F-150 Bumper on 88 Bronco what are the differences in shape? Mush's 88 Aftermarket Products 0 06-22-2004 03:45 PM
hood scoops on an 87-91 ford pickup/bronco hood? Mush's 88 Appearance & Dress-Up 5 05-08-2004 12:21 PM
Tags
1995, 94, black, bronco, broncos, compartment, engine, flareside, ford, forum, gears, photograps, photos, pictures, stock, trucks, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
