Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign in using an external account
Register Forgot Password?
1978 - 1996 Big Bronco SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
  #226
Old 10-24-2011, 04:01 PM
ford1977owner's Avatar
ford1977owner ford1977owner is offline
ford1977owner is gaining momentum as a positive member of FTE.ford1977owner is gaining momentum as a positive member of FTE.
kixfan1986 kkixfan1986 camosniper22
Quote:
Originally Posted by Edgethis View Post
I wanted to put a light bar like that on mine, now you've got me worried ErrorS. KC Lites aren't cheap...I would be very sad/mad/angry if the bar flew off with them on it.
i think id be very mad if one flew off especially because their not cheap lol
__________________
Drive a ford, Run over a chevy
PA Chapter Member, Shane
  #227
Old 10-24-2011, 07:39 PM
ErrorS ErrorS is offline
ErrorS is starting off with a positive reputation.
It sort of uses the rubber boots that sit in your gutters to keep it from sliding back.. it's just not a super secure design. I did go a year without it sliding off, though I had to retighten and readjust it every once in a while. It didn't do well with overhanging trees, I constantly had to plug the wires back in, readjust the lights and readjust the bar itself.
I wasn't sure about the looks either, with the light bar the Bronco looks a lot bigger, without it the Bronco looks a bit more slick, more offroad and less mall-crawler. Plus, with the lightbar I can't fit in car-washes, without it I can. But if I were to ever put a light bar back on, I would *have to* have it bolted at some point.
Oh, and Carr's customer support rocks, just have to give credit where credit is due.
__________________
1990 - Bronco. 351W. E40OD
Run codes first, ask questions later.
  #228
Old 10-24-2011, 07:43 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Is it possible to drill a hole in the gutter where it mounts to put a bolt all the way through? I'm not a fan of drilling holes in my truck, but i wouldn't want $300 worth of lights and a bar flying away.
__________________
-Brett
Currently Ford truck-less
old Zebra Build thread RIP
1968 Mustang Coupe Booms Restomod Thread
  #229
Old 10-24-2011, 07:58 PM
It has legs that sit in your gutter, then a sort of L-shaped clamp-like thing that goes underneath the gutter and bolts to the side of the lightbar. It keeps it from moving up or down, but doesn't keep it from sliding with *some* force, usually it isn't an issue, the rubber boots keep it in place decently.
Anyways, on the L-shaped clamp, you could probably just put a self-drilling screw through it into your roof or gutter to keep it from sliding back. The screw wont be taking much force, so even a small, non-invasive one should do it.
Keep in mind I was on gravel at high speed, it probably just vibrated itself loose. I doubt 99% of people with the same lightbar would have the problem. If you're not trying to be a prerunner in your Bronco you're not gonna have any trouble.
Never lost it on the interstate, but would check it every single time I thought I was going to go on the interstate.
__________________
  #230
Old 10-24-2011, 10:15 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 is gaining momentum as a positive member of FTE.Pkupman82 is gaining momentum as a positive member of FTE.
Sorry for not having some good pics at the moment. The picture in my sig is my 79 Bronco. It's motivatated by a basically stock 460 with a C6/Np205 combo behind it. The 9" and D44 are loaded with 4.88s, the front has a Dana Powr lok lsd and the rear has a full spool. The suspension is 6" Superlift, all spring... no blocks. I'm rolling on 37x12.50R15 Super Swamper Radials with cut out wheelwells. I built a set of heavy duty bumpers for it with receiver hitches and d-rings at both ends. It has dual batteries and a Saginaw power steering conversion. I have a bunch of plans for it to be done over the winter, hopefully it all works out.
__________________
1977 Ford F250 XLT Ranger 4wd/ 351m/ NP435/ 205
1979 Ford Bronco XLT Ranger/ 460/ C6/ 205
1984 Ford F250 XL 4wd/ 6.9 IDI/ C6/ BW1345
1984 Ford F150 4wd/ 300/ NP435/ 208
1996 Ford F150 XLT 4wd/ 300/ ZF5/ BW1356
  #231
Old 10-24-2011, 10:19 PM
Edgethis's Avatar
Sounds like an awesome rig Pkupman, looks great from that teaser size sig pic. I hope we'll get to see some fullsize pics soon!
__________________
-Brett
  #232
Old 10-24-2011, 11:22 PM
for the light bar, i imagine if your good with fabrication work, you could fab your own brackets to secure it alittle better, just a thought i dont know too much about the light bars tho
__________________
  #233
Old 10-25-2011, 04:08 PM
huggyb1972's Avatar
huggyb1972 huggyb1972 is offline
huggyb1972 has a good reputation on FTE.huggyb1972 has a good reputation on FTE.
I painted it underneath
Click the image to open in full size.
Took it to the Jamboree nationals
And now it's covered in mud again
__________________
Drafthorse 89 Ford Bronco
351W, ZF5-47, BW1356, 6 inch lift,
Sterling 10.25 rear l/s, Dana 44 front L/S,
8 lug, and 37x12.50 Baja TA.
  #234
Old 10-25-2011, 07:27 PM
Edgethis's Avatar
Looks real sharp Huggy. I would've avoided painting the hub/rotor, but everything else looks nice and shiny. I'm sanding my frame and underbody down and painting with ultra flat!
__________________
-Brett
  #235
Old 10-25-2011, 08:18 PM
huggyb1972's Avatar
I greased the rotor now the brakes don't squeak.
  #236
huggyb1972's Avatar
  #237
Old 10-25-2011, 09:10 PM
I paint my rotors sometimes, it never causes any real issue.. sorta helps me visualize where the pads are seatings, how they're grabbing, etc... plus you get a nice protective coating on the parts of the rotors the pads don't contact.
__________________
  #238
Old 10-25-2011, 09:13 PM
Edgethis's Avatar
Quote:
Never thought about that. Thanks for the info, i wasn't sure if the paint would gum up the pads or anything.
__________________
-Brett
  #239
Old 10-25-2011, 09:25 PM
huggyb1972's Avatar
Mine did a little shudder thing but smoothed out in a few stops. Painted metal always looks better.
__________________
  #240
Old 11-06-2011, 01:11 AM
drbalazo drbalazo is offline
drbalazo is starting off with a positive reputation.
Tags
1995, 94, black, bronco, broncos, compartment, engine, flareside, ford, forum, gears, photograps, photos, pictures, stock, trucks, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Post pictures of your F150 Trail Rig or Rock Crawler here! derherr65 Offroad & 4x4 52 02-06-2013 10:42 PM
Members Rides - Tell us about your Bronco fordborn 1966 - 1977 Early Broncos 53 09-26-2006 06:51 PM
calendar girls Fordlover55 1966 - 1977 Early Broncos 9 11-26-2004 12:23 AM
92 - 96 Bronco/F-150 Bumper on 88 Bronco what are the differences in shape? Mush's 88 Aftermarket Products 0 06-22-2004 02:45 PM
hood scoops on an 87-91 ford pickup/bronco hood? Mush's 88 Appearance & Dress-Up 5 05-08-2004 11:21 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
