99 2.5 problems
Old 06-07-2012, 09:08 PM
sawz5's Avatar
sawz5
sawz5 is offline
99 2.5 problems
i bought this 99 ranger supposedly in good running condition, BUT you all know what's coming right. i had my nieghbor put his scanner on and he says it may have a broken or weak valve spring on no.2 cyl. now since he is remodeling his son's house he don't have time. so i need help from some of you guys. i need step by step how to change a valve spring in an overhead cam engine. thanks, rick
Old 06-07-2012, 10:32 PM
critterf1's Avatar
critterf1
critterf1 is offline
How did the "scanner" tell you that it's a valve spring problem.
Old 06-09-2012, 06:04 AM
sawz5's Avatar
sawz5
sawz5 is offline
i guess i should have said his scanner showed a misfire on no.2 cyl. then he said it might be a weak or broken spring.
Old 06-09-2012, 01:07 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
A misfire can be caused by many things, such as a bad plug/plug wire, coil problem, or fuel injector issue. Even a small vacuum leak can cause a single cyl to have a misfire.
Yes, a weak or broken valve spring can cause this, but check the external stuff first. Especially if the misfire is intermittent.
Old 07-03-2012, 10:01 PM
sawz5's Avatar
sawz5
sawz5 is offline
thanks Mr. Rogue, apperantly a broken or weak valve spring can be fixed by changing to
a lighter weight oil. i put 10w40 in when i changed the oil my mech. found a thech paper from ford saying use 5w20 because heavier oil stayed in the lifters causing them to hold th valve open. i changed to 5w20 and so far the engine is running ok, so i guess i'll wait to see the outcome.
Efontenot555
6.2L V8
01-20-2021 08:42 PM
Batt204
07-09-2018 01:53 PM
Larry85355
Modular V8 (4.6L, 5.4L)
02-22-2013 10:38 AM
Shawns Fords
06-10-2011 11:21 AM
79f-250custom
08-14-2006 01:07 AM
Quick Reply: 99 2.5 problems
