"Check Coolant Additive" - Ford Truck Enthusiasts Forums
Old 05-04-2011, 08:10 PM
Rick Cargo's Avatar
Rick Cargo Rick Cargo is offline
Rick Cargo is gaining momentum as a positive member of FTE.
Driving to work this morning and I get a notification "Check Coolant Additive". Sure, I've got 12,100 miles on it but come on. A dealer in Temecula wants $79.95 to check the coolant additive. They dip a test strip in the coolant to check it out. Then I called my dealer in Hemet and he said to bring her in in the morning and we will check the coolant at no charge. He says it only takes a few minutes to check provided the engine isn't too hot. I guess the "coolant additive" is something that the computer monitors to make sure the coolant is still good. Anybody know of this?
Old 05-04-2011, 08:16 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
It's similar to the oil monitor is my understanding.
The computer doesn't really know the condition of your coolant but based on your usage (lots of towing or idling, etc), the computer then determines when a check is needed.
The test strip is supposed to show a certain color and you match it to a chart which instructs you what to do.
And darnit, I forgot to ask for test strips while I was at the dealer the other day.
I'm at 15,000 and I want to check regardless of the message.
Old 05-04-2011, 08:42 PM
Rick Cargo's Avatar
Yeah, but even if you can test it yourself how do you get rid of the annoying warning message?
Old 05-04-2011, 09:01 PM
lexustbs's Avatar
lexustbs lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
You clear in in the INFO screen. Should tell you how to in the owners manual.
Also, here is how to test your coolant:
1st. Check for the presence of nitrates in your coolant (There should be none) with Rotunda test kit number 328-00001. If there is, you have to flush and refill.
2nd. Check the percent of glycol in the coolant. use the same rotunda kit for this as well. Should be between 40-60%. If this is not the case, you have the flush the cooling system.
3rd. Check the Reverse Coolant Alkalinity. You need Rotunda test kit number 328-00008.
If its low, you must add some stuff included with the kit, if its high, you add another stuff to the coolant. If its ok, move to next step.
4th. Check coolant corrosion ability. You need rotunda kit number 328-00008, which is the same as last. Follow the instructions included in the kit. If it does not pass, then you have to add a bottle of revitalizer. Ford part number vc-12. Otherwise your coolant is good to go.
WOW. I would charge $75 for this too.
Link to supplies
https://rotunda.spx.com/en-US/Pages/...x?itemID=16878
https://rotunda.spx.com/en-US/Pages/...x?itemID=22023
Old 05-04-2011, 10:17 PM
kereams kereams is offline
kereams is starting off with a positive reputation.
Is there anyone that sells a lesser quantity? Those kits seem like enough for a few hundred thousand miles, no?
Old 05-04-2011, 11:30 PM
Painted Horse's Avatar
Painted Horse Painted Horse is online now
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Go to the info screen and choose Coolant and press and hold the OK button until it clears.
The message will appear about every 600 hours.
Service Manager said he would test it next time it was in. He wasn't too worried about this first mesage. especially since he knew I would be in for a oil change in a few weeks.
Old 05-05-2011, 11:53 AM
djjoshuad djjoshuad is offline
djjoshuad is gaining momentum as a positive member of FTE.djjoshuad is gaining momentum as a positive member of FTE.
they should change that message to "Hey, it's time for your regularly scheduled coolant additive test!"
That's what it means, anyway
Old 05-05-2011, 12:35 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is online now
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
Thanks lex. My kit is on its way.
Old 05-05-2011, 01:45 PM
lexustbs's Avatar
No prob. The price did not bother me because I have read too many horror stories about the wrong coolant being added, or the wrong strips being used. Plus, you service department is going to change you out the wazoo anyways if they do it right or wrong.
With all the emissions and high power these motors are putting out, the coolant system is so very important. This is coming from experience in the class 8 trucks.... Oh boy.
Old 05-05-2011, 08:00 PM
Rick Cargo's Avatar
I was at the dealer for all of maybe 15 minutes. It took the guy longer to show me how to reset the message than it did for the actual test. He said that he usually doesn't reset the messages. All done at 'no charge'. I like that.
Old 05-05-2011, 10:50 PM
BTyner41 BTyner41 is offline
BTyner41 is starting off with a positive reputation.
I took mine in this morning for this message (12,300 miles) and the service manager told me the same thing as he reset the message.
Old 05-06-2011, 06:09 PM
xxtra xxtra is offline
xxtra is starting off with a positive reputation.
$73+ for the testing kit only?
Why not just flash the coolant every certain miles. I think 4 gallons of coolant + distilled water will run less than $73. Does the coolant flush need other additives?
Old 05-06-2011, 06:59 PM
lexustbs's Avatar
You have it wrong. $75.00 for a kit that will last the life of your truck vs. You saying to change the coolany every 16,000 miles. Plus the peace of mind knowing my coolant was checked right is well worth my $75. Just my 2 cents. Now I have a total of $75.02 invested in coolant testing.
I'll state again, coolant systems are very very important to this truck..... Just as important as your oil.
Old 05-06-2011, 07:04 PM
JReinert JReinert is offline
JReinert is gaining momentum as a positive member of FTE.
I paid $20 a gallon for the coolant at my local Ford dealership. I had 50k on the truck and decided to change it.
Old 05-06-2011, 07:36 PM
lexustbs's Avatar
Quote:
Whats it take to change both systems? 10 gallons?
Coolant flush PlayersZ28 6.7L Power Stroke Diesel 11 11-26-2016 05:44 PM
Message center says check coolant additive rickatic 6.7L Power Stroke Diesel 52 01-07-2013 04:35 PM
Check Coolant Additive ??? Canadian F250 6.7L Power Stroke Diesel 5 11-03-2012 03:15 PM
"check coolant additive" Warning rsyauto 6.7L Power Stroke Diesel 2 12-10-2010 10:35 PM
Transmission Slips thecitrusbelt Escape & Escape Hybrid 2 08-02-2010 02:05 PM
Tags
2011, 350, 67, additive, check, colant, cooland, coolant, diesel, f350, ford, low, message, resetting, truch, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
