Need Advise: Belt, Tensioner ETC.
Old 05-04-2011, 01:28 PM
B Big's Avatar
B Big
B Big is offline
Ah, its time I spend a few bucks on maintenance items.
The belt tensioner on the truck has shifted out of true & started to eat the belt. I'll be getting a Goodyear Gator Back belt & I need a new tensioner.
What brand tensioner do you guys like & where is a good place to buy?
Also I need to get a new lift pump for fuel plus I'm gonna get a new fuel bowl & hoses. What brands & where to buy'em?
We will be moving north ward soon & a friend says to disconnect or disable the ABS system before we get into snow & ice, anyone else do this?
Need rear dually tires too, any thoughts? I'm torn between spending cash on good tires or because they are duallies just getting some no names.
I'll probably do rear brakes while I have the wheels off too, any thoughts?
Thanks Guys!!!
Old 05-04-2011, 01:52 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
Got my belt tensioner here Amazon.com: Gates 38119 Belt Tensioner Assembly: Automotive
It's the 'upgraded' unit, so the arm is longer, but it works. you don't use the re-use the factory washer on it, as the bolt head recesses into the unit for belt clearance. (learning from my mistakes). Good call on gatorback, that's what I run too.
Autoparts store such as autozone or whatever should have pump. IIRC there all carter pumps, regardless of the packaging. Clay @ riffraff has the hoses (and the pump if you're looking to source online), or you can make some up out of from Goodyear EP SAE 30R9, also available at autoparts store like napa
Never disabled my abs, but the module is behind the glovebox IIRC...
Hope this helps some, I'm sure others will chip in more answers
Old 05-04-2011, 01:57 PM
jtexfisher's Avatar
jtexfisher
jtexfisher is offline
"Need rear dually tires too, any thoughts? I'm torn between spending cash on good tires or because they are duallies just getting some no names."
When I did my DRW conversion on the E350 I went with NTB house brand tires. NEVER AGAIN! They WOULD NOT balance. Thank goodness a few years wore them out and I had to replace them. I went with the Goodrich Commercial T/A and the difference is night and day. Not that I'd recommend that tire for you. Up in that stuff you'll need a different tread. These are a "don't even look at anything not paved" pattern. E-350 15 passenger vans are not fun to get unstuck. My point being that a good quality tire was worth the extra cash in my case.
Not much to add on the belt tensioner.
Old 05-04-2011, 08:04 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Wink
I have that one, but if you really want a upgraded unit buy this dual belt tensioner (it needs some mod in the braket and a longer belt tho).
Old 05-04-2011, 08:40 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
Jose, that one does look way better. That an SD unit or where do you get it? Any idea what needs to be modded on it?
Sorry for the thread jack
Old 05-04-2011, 09:04 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Yes its a SD unit, NAPA has them. Im going to look for the mod.
Old 05-04-2011, 09:09 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Old 05-05-2011, 05:51 AM
Robbgt's Avatar
Robbgt
Robbgt is offline
Thank you sir! Might do this next go around, like the SD unit alot better. Tried to rep but you know the drill...
EDIT: Also Big B, sorry for the thread hijack. Least that gives you a couple options on the tensioner
Old 05-05-2011, 09:26 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Thank you sir! Might do this next go around, like the SD unit alto better. Tried to rep but you know the drill...
Robb, you are welcome, anytime, no problem.
And thanks for tried.
1996F150XL
05-27-2014 06:16 PM
Piolet
05-14-2012 05:48 PM
Sullid01
05-01-2012 06:04 AM
eatont9999
17
05-11-2011 11:17 PM
TexasDiesel97
17
05-31-2010 03:10 PM
Quick Reply: Need Advise: Belt, Tensioner ETC.
