Power Steering Pump or Steering Box
Truck is extremely difficult to turn while pulling out of my driveway and going hard over prior to straightening out, seems like its only at slow speeds. Fluid in the pump is at correct level, the box does leak (not sure if that is the problem), tires are not rubbing.
Does this sound symptomatic of failure of the pump or box or both?
If I go to a junkyard what years can be swapped into a 93 f350? I'd assume I could use a van pump as well? Thanks Fellas
bigdieselhighboy
18
03-13-2015 11:30 PM
jaye
09-28-2008 10:03 AM
