1968 f250
Old 05-04-2011, 01:10 PM
billypepper's Avatar
billypepper
billypepper is offline
Unhappy 1968 f250
Hey im in need of anyone who is good with wiring. I had a 1968 ford f250 and a 1978 f150 and i need to wire up the motor to be started and run and all i got is the 1978 wiring from the cab and the wiring from the 1968 360 motor how can i make this work
Old 05-04-2011, 01:33 PM
billypepper
oh yea the 1968 is a 360 with pionts and the 1978 is breakerless
Old 05-04-2011, 03:38 PM
rustywheel68's Avatar
rustywheel68
rustywheel68 is offline
if i follow you, you've got the '68 motor in the '78 chassis?
1. hook up the "hot in run" wire from the ignition switch to the coil (make sure there's a resistor somewhere in line here.)
2. hook up the wire from the "I" terminal on the starter solenoid to the coil as well
light it up.
http://www.allfordmustangs.com/forum...ntignition.jpg
Old 05-04-2011, 04:07 PM
billypepper
its a 1978 f150 body on a 1968 f250 chassis i look into your advise as soon as i can still got to bolt down carb run fresh break lines and hundred other things what was i thinking it woulda been less trouble to just buy an old 4 wheel drive truck than to do all this
texasblue55
23
07-20-2021 06:06 PM
fzeed
36
09-01-2017 06:07 AM
Xand17
06-14-2017 04:28 PM
Joseph Lameo
Engine Swaps
03-29-2017 03:27 PM
RENA1608
12-14-2016 02:47 PM
Quick Reply: 1968 f250
